///M3 Forum
Old 12-06-2012, 11:46 PM   #1
TramRam
My Ride: '02 M3 Blk/Imola SMG
Post M3 Spark Plug Life?
I got my M3 with 80k on it and according to the previous owner, the plugs have not been changed. What is the typical mileage when there's benefit to replacement? I've checked and found no posts on this subject but know that plugs on 'newer' cars are typically intended to not need replacement for 100k miles. Maybe I just HAVE to mess with but I know how good fresh plugs feel in a nice engine and can improve mileage at the same time! I'm lucky to get 16 -18mpg in in town with some highway driving each week and think I can do at least a little better! I get about 24mpg at highway speeds of 75mph on a long highway run. This is calculated mileage not what the gauge says.
KEEP THE LEFT LANE CLEAR FOR FASTER MOVING TRAFFIC
TramRam is offline   Reply With Quote
Old 12-07-2012, 12:29 AM   #2
Arock1092
My Ride: Bmw M3
80k on an m without replacing spark plugs.(yikes).. I did mine with inspection 2 at 60k, get them done asap!
Arock1092 is offline   Reply With Quote
Old 12-07-2012, 06:08 AM   #3
jayb328i
My Ride: E46 2000 328i
Nope--would not wait until 100k. I would change at 80k. You need to look at each plug to verify its condition, and I would not go through that effort without just changing them and netting possible better performance. PS--also once had a plug that seized in place (no anti-seize coating) --would want to change at 80K or sooner.
jayb328i is offline   Reply With Quote
Old 12-07-2012, 07:25 AM   #4
shanneba
My Ride: 2003 330Ci
The BMW suggested plug change interval for the E46 M3 is 60,000 miles.
It is also the the interval for the valve adjustment, Transmission and diff fluid changes for the M3.
You can download the BMW Service checklist here:
http://www.linquist.net/motorsports/bmw/service
Owners manuals are here if you need one:
http://www.linquist.net/motorsports/bmw/3manuals
Join BMWCCA
Old 12-07-2012, 07:25 AM   #5
steve bettencourt
My Ride: 2003 m3
I would say for shure 80km is 50 miles I changed mine and you will see a difference
steve bettencourt is offline   Reply With Quote
Old 12-07-2012, 07:28 AM   #6
TerraPhantm
My Ride: M3 & ZHP
60k
Old 12-07-2012, 09:51 AM   #7
328ci906
My Ride: 2003 M3
60-100k is what I've read as well. It's on my maintenance list for this spring.
-2000 E46 328i
-2006 E60 M5
328ci906 is offline   Reply With Quote
Old 12-07-2012, 10:54 AM   #8
McGary911
My Ride: 2004 M3 Convertible
I did mine at about 62k, shortly after I purchased the car, as I didn't know if it had ever been done. It's easy to do in an hour, and the plugs while a bit pricy for plugs.....won't break the bank. Mine looked pretty good when I took them out, but feel better knowing there are 6 fresh ones in there. I took the opportunity to clean the parts of the engine that I exposed during the work, so not only did I get new plugs which I can't see, my engine bay looked a lot nicer.
McGary911 is offline   Reply With Quote
Old 12-07-2012, 11:29 AM   #9
TramRam
Thanks for the good feedback guys & the links Shanneba. In time, I'll hopefully be able to FEED the forum more and glean less. From the way my car drives, my guess is that all is in decent order but you don't know what you don't know until you do know! I've got a fresh set of plugs sitting, waiting to go in now. As far as using anti-gallant on plug threads, I've always just used some fresh motor oil and never had any extraction issues even on high HP turbo applications.
Old 12-08-2012, 12:21 AM   #10
illestminimike
My Ride: Project Drama
I have mine sitting in my room. I'll change them one day.
Old 12-08-2012, 12:31 AM   #11
djantlive
My Ride: E46 M3
you can always pull one out and see if it is in bad shape before you buy and replace all.
djantlive is offline   Reply With Quote
Old 12-08-2012, 11:45 AM   #12
TramRam
Hey, with 80 kmi on them now, they are coming out!!! The ones I determine to be in the best shape will go on the 'just-in-case' shelf and I'm done and SHOULD be good for another at least 60k! Might be into another M by then...possibly a 5! Heading out to my buddy's shop right now to do its 1st oil change (with Redline 10w60) and plug replacement (NGK Iridiums) since taking ownership of this sweet machine!
maintenance, mileage, spark plugs
