///M3 Forum
Old 12-07-2012, 07:29 AM   #1
Cayne23
My Ride: 2002 m3 convertible
battery light
Today while i was driving my battery light came on. It stayed illuminated while i was driving. When i stopped i popped the hood and looked at the alternator. The belt is good. Is my battery dying? there has been times when i try to lock or unlock my car and.i have to push the button a couple of times. And another question. Could a low battery cause my tps sensors to not communicate and set iff my eml light? Plz help
Cayne23 is offline   Reply With Quote
Old 12-07-2012, 08:26 AM   #2
Cayne23
Maybe i should say also, that i was in second gear. I pushed my sport button to pass some traffic and thats when the battery light came on
Old 12-07-2012, 09:02 AM   #3
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
keep an eye out. Once the battery light started illuminating, in about a few days I ended up getting stuck by the side of the freeway as the battery drained due to a failed alternator.
I rebuilt the alternator for like a hundred dollars and it failed on me within a week.
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
Old 12-07-2012, 09:35 AM   #4
Cayne23
Yea my indy shop said 690+tax for new altenator. Anyone wanna buy an m3 with a new clutch? i cant take this anymore and neither can my bank account
Old 12-07-2012, 09:42 AM   #5
zander271
My Ride: 6spd ZHP/5sp XI
Didn't you just get your car?
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 12-07-2012, 09:49 AM   #6
MachRc
E46Fanatic
MachRc's Avatar
Just make sure if it is the alternator(have it tested at a shop, usually free of charge) make sure you get a new alternator instead of a rebuild. ANd try avoiding draing the good battery. Its bad enough the alternator is going out, no need to buy an extra battery.
Old 12-07-2012, 10:15 AM   #7
Cayne23
Yea +1 on not getting a rebuilt. It will b oem. Yea i've had the car for 4 months and i've had to put in a new clutch, i need my tps sensors replaced and now the altenator. So like 3k i've had to spend on it in the past month the tps sensors r gonna get done when my alt gets replaced. This is my dream car but god damn it, its becoming a nightmare
Old 12-07-2012, 11:44 AM   #8
Cayne23
Can someone point me in the right direction for a diy replacing my alt thanx
Old 12-07-2012, 12:08 PM   #9
choxor
My Ride: JDM
This is why you have spent $3k on the car. TEST before you replace. It could easily be your battery. Randomly throwing parts at a car is always expensive. ESPECIALLY an M3.
Old 12-07-2012, 01:01 PM   #10
Cayne23
Will b close to 3k after alt install. How do i test? Me and my car r about 35 miles from home. My voltmeter is at home.
Old 12-07-2012, 03:51 PM   #11
Cayne23
Ok omw home from work. Car is completly warmed up, and the batt light has been off the whole time. All electronics inside my car are off, except for my heat. Its cold. 30 miles to go. Wish me luck lol
Old 12-07-2012, 05:21 PM   #12
MachRc
E46Fanatic
MachRc's Avatar
you can do the non smart way test it like I did(not recommended but I didnt really care) start car, pull the positive cable and see if the car stays on.
On new cars doing this will turn off the car as there are failsafes, but not in the e46.
take it to an alternator shop/ independent
Old 12-07-2012, 05:25 PM   #13
Cayne23
Alright Choxor u were right. Gonna go to autozone and get my alt tested. Made it home. Popped off the batt cover and saw the batt had a good charge to it, indicated by the green dot in the sight glass. Tested the batt. 12.5 v when car is off. 14.8-14.9 with car running hmmm...... Yea, gonna get them tested tomorrow
Old 12-07-2012, 06:42 PM   #14
Cayne23
I just saw on youtube how to test the battery and alt using the test mode in the car. With the car off my volt reading was 12.5volts. Started the car and it went uo to 13.9-14.0. Turned on the heat, same thing. Radio on, stayed the same. Turned on headlights, 13.8-13.9volts. Turned on rear defrost and front defrost, 13.6-13.5volts. Turned on both seat heaters full blast, 13.5-13.4volts Reved the engine,13.7-13.8volts. Idled down, 13.5-13.6 with everything on. Is the alternator slowly starting to go?
Old 12-10-2012, 05:39 PM   #15
McGary911
My Ride: 2004 M3 Convertible
It sounds like your alternator. My car had the light come on while driving to work. I drove to lunch and it was off. I took it to a good Indy, and they said it was charging like crazy. They took it for a spin and got the light to come on. It turns out it was working only sporadically. Things like that never get better, only worse. It was a touch over $500 for the alternator, belt and one pulley. These cars use a lot of juice, so once it craps out for good it'll strand you.
I believe all of the alternators for our cars are rebuilt these days, even the shiny one from the dealer.
McGary911 is offline   Reply With Quote
Old 12-10-2012, 06:14 PM   #16
Cayne23
Yea im tryin to baby it now. Going in the shop on thursday. Gonna get my tps sensors replaced and my alt. Here goes another 1000 bucks. Oh well, at least i'll b able to feel my cars full power again. Havent felt it in like a month. Being that it was tps failing, then release bearing broke, got a new clutch, release bearing, shift fork and slave cylinder. And then the battery light came on. Well on the bright side i have all these new parts in my ///m. Lol. Not bad considering i only paid 15k for the car and will have put almost 3k into it. Still below my 20k max limit for a car lol
