Old 12-08-2012, 01:37 PM   #1
Valkyn
My Ride: 2000 328i
M52TU bottom end differences
I bought a used short block out of a 2000 328CI to replace my overheated engine in my 2000 328I. The replacement was from a car built in 8/1999 and my car was built in 4/2000.
I am swapping over parts and noticed the bottom end is slightly different. My engine had these triangle things that go from the main cap bolts to the windage tray bolts:
The new engine dosent have these:
The only impact I can think of is windage tray clearance, as they space it up abit. I trial fitted the windage tray on the new motor and it dosen't hit the crank and there still seems to be plenty of clearance.
Is there any reason I can't just swap my windage tray over? Anyone know? I would like to avoid swapping them over to the new engine since from what I've read the main bolts are torque to yeild, so I would need to replace them.
Valkyn is offline   Reply With Quote
Old 12-08-2012, 02:04 PM   #2
lmr2wil
My Ride: '00 328Ci
RealOEM shows that they added those support plates in 1/2000. They also show that the block changed at the same date. I would probably keep the engine as is it came myself.
Luke
lmr2wil is offline   Reply With Quote
