Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 12-10-2012, 02:58 AM   #21
HighBoostin330
My Ride: 2002 Stock 330Ci
Originally Posted by AndyN View Post
hmmm ya I hear what your saying, Building the motor I would be best off to buy ESS's stage 3 but looking from build threads there is much more expense than just the basic TS3 kit... It is worth considering so I see your point..
But at the moment as I want the car back on the road due to my e30 being promoted to daily driver! Im able pick up a reconditioned b30 block for (euro)1000 which is pretty class.. If that blows Ill eat my hat and take your advice!
You want my TS3 pistons and fuel injectors? Then I'd sell my TS3 setup as a TS2+.
HighBoostin330 is offline   Reply With Quote
Old 12-11-2012, 08:41 PM   #22
cd330
ModZombie Moderator
cd330's Avatar
My Ride: manual stl gry 330i
Originally Posted by ///MPR77 View Post
i am unable to remove this picture.
Do Not REFER to this for routing
This is the tensioner he referred to.
It attaches to the OFH which is actually a semi hollow part, that the alternator, and PS pump attach to.
It certainly isn't a very robust part being that it is hollow.
go to your user cp, bottom left under Misc, Attachments, see if you can delete it there.
cd330 is offline   Reply With Quote
Old 12-11-2012, 08:44 PM   #23
///MPR77
My Ride: 323i ZSP/ZPP
Originally Posted by cd330 View Post
go to your user cp, attachments, see if you can delete it there.
Yeah couldn't do it in advanced editing on the message.
I will check the user control panel.
Thanks Chad.
Some say his notoriety is so profound, that he was able to drop the e46 in his name, and just like "The Highlander" there can only be one....all we know is he is called "Mango"
///MPR77 is online now   Reply With Quote
Old 12-11-2012, 08:54 PM   #24
cd330
ModZombie Moderator
cd330's Avatar
Thanks Chad.
I know I can do it on my user cp, just don't know if you can
Old 12-11-2012, 11:05 PM   #25
///MPR77
It worked, thanks again.
Old 12-12-2012, 05:08 PM   #26
AndyN
My Ride: ESS TS2 325ci
Originally Posted by paraklas View Post
Where did you find the B30 block for €1000 ?
From a Company in the UK, Sorry my bad it works out about 1500 euro its around 1200 pounds sterling.
Some updates:
Contacted ESS on the upgrades needed from the TS2 on the b25 to b30
Elbow: 450USD
Injectors 359USD
Pulley 95USD
Belt 62USD
New software 795USD
I didnt think there was much of a difference between the TS2 on both engines..
1) Why are the injectors need to be upgraded, arent they both large Bosch ones?
2)The pulley I would have thought would be the same size as the b25 as the engines are identical, unless the crank diameter is different, anyone know this?
3)Is this not just that little piece of rubber that attaches the throttle to the air filter? If so 450USD?!!
4) 795 is fair price for software provided they dont mess it up this time and I have to resend it back to them!
AndyN is offline   Reply With Quote
Old 12-12-2012, 05:50 PM   #27
HighBoostin330
I believe crank and rods are different between the two motors.
Elbow is the metal piece that you mount your throttle body to. From my understanding, B30 has a bigger throttle body than the B25 - thus the reason for the elbow change.
Some updates:
Elbow: 450USD
Injectors 359USD
Pulley 95USD
Belt 62USD
New software 795USD
Old 12-12-2012, 06:15 PM   #28
AndyN
So I am presuming if the crank is different in order to keep the ratio to 8 psi a different pulley size is needed, Correct?
So its just the elbow that changes or do I need to change the throttle body also? Its all starting to add up I can only image how you felt doing the TS3!!!
Old 12-13-2012, 11:48 PM   #29
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
My Ride: ESS TS2+ 330Ci
Send a message via Yahoo to Dirtboy
Yup, b30 throttle body is bigger.
Dirtboy is offline   Reply With Quote
Old 12-18-2012, 12:17 PM   #30
AndyN
UPDATE:
So it turns out the reconditioned engine that I was supposed to get isnt in stock so could have to wait for a good while to get a reconditioned one.
There is the option of another engine that has 90,000 miles on it for much cheaper. Will this be able handle the TS2?
Old 12-18-2012, 06:24 PM   #31
SweTurbo
Banned User
My Ride: 323i -98
UPDATE:
Why not go for a rebuild ?
Old 12-18-2012, 06:31 PM   #32
AndyN
I have ordered the 3.0L with 90,000 miles on it and im gonna rebuild the 2.5 while its out but may put that in my e30.
I just wanna get the e46 back up and running again! I miss it!!
Hopefully the new engine will hold up better than the 2.5L
Old 12-18-2012, 08:49 PM   #33
TxZHP04
My Ride: ESS TS2+ ZHP
You really need to tear down the old motor to determine what went wrong before moving forward with any other plans....
Old 12-18-2012, 09:22 PM   #34
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
You need to tear apart the engine and look at both the pistons and the spark plugs. Until you figure out the cause of the problem, I would not run whatever replacement engine you will have sources. For example, if it was a fuel system related failure, you would still need to address that....
Again, this should be the priority.
PEI330Ci is online now   Reply With Quote
Old 12-19-2012, 05:20 AM   #35
AndyN
Yes I agree guys, the old engine is coming out and before I start up the new one I will strip it down. My mechanic seemed to think (now bear with me on this as I didnt fully understand him!) Something about oil getting into the clyinder and during compression the oil got blown into sump and out through VCG?
Another thing that may be important is that I used to be reading 11psi in 5th gear even though the software I thought limits it to 8psi. When I would put the foot down in 5th sometimes I would get check engine light and car would misfire like a B!tch.
Also it would have terrible cold starts with it stuttering and cutting out etc..
I am presuming the engine was giving up for awhile before this..
Old 12-19-2012, 05:25 AM   #36
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Do you have the OEM exhaust manifolds still on the car? (Headers)
Old 12-19-2012, 05:33 AM   #37
TArse
My Ride: 03 330xi, 87 325is
Sounds like maybe a tuning issue. Or you could've been blowing oil.
TArse is offline   Reply With Quote
Old 12-19-2012, 05:39 AM   #38
AndyN
Yes its RHD so the only ones I can find are by schiedmann in denmark and they have a 75 working day wait!!! You think this may be a problem?
Ya I think tuning issue, When I got the ECU back from them it didnt work so had to resend it to them again and then it worked second time but now Im worried about them messing it up again on my new engine!
Any particular gauge I should buy to keep an eye on things, I have boost and oil temp, maybe I could keep an eye on A/F this time??
Old 12-19-2012, 06:24 AM   #39
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
It is possible that your engine failure is the result of back-pressure from failed catalytic converters. There are other possible variables, but this is one possibility to consider.
I don't think the tune is the problem.
You have a mechanical issue that has changed the boost pressure from 8 PSI when you first installed the kit, to 11psi just before the engine blew.
I could be wrong, but this does not point to the software?
Old 12-19-2012, 06:34 AM   #40
AndyN
I did throw a code every now and again for Pre/post cat sensors?Cant remember which one though.
I was always able to have more boost than 8psi since i installed the kit.
Probably should have done something about that then! haha
