E46 Xi Forum
Old 12-07-2012, 02:24 PM   #1
kevin.john1
My Ride: 2002, 325xi wagon
sway bar links
I noticed one of my boots have separated, is there a reason to replace both sway bar links at the same time? I have 120,000 miles on this car.
Kevin
kevin.john1 is offline   Reply With Quote
Old 12-07-2012, 02:38 PM   #2
///MPR77
My Ride: 02 ///M3 Tri-Ped
I replace both of them, at the same time, because they are relatively cheap.
I don't see why you couldn't just replace one side, assuming the other side is still firm.
I would pull the other one off, and check the ball joint for slackish play.
Old 12-07-2012, 02:48 PM   #3
SamDoe1
My Ride: 4cyl of fury
If one is gone, the other is too. For the cost of less than $30 each and less than 30mins wheels up to wheels down, why wouldn't you do both?
Old 12-07-2012, 03:12 PM   #4
///MPR77
Exactly, to inspect the other side is half the job of replacing it.
Old 12-07-2012, 03:44 PM   #5
Kubica
My Ride: 2003 325xi
The only front suspension component that isn't always replaced in pairs are the control arms.
You do both links at once. No debate.
And there's room to grab the links to check for play without removing a wheel or jacking up the car.
Old 12-07-2012, 05:23 PM   #6
///MPR77
Yeah there is room, but without getting the front up in the air the links will be loaded, and very hard to feel for subtle play, which can still clink and clunk.
I suggest jack the car from the rear pad enough to get a jackstand under the vacant front Jack pad.
Lower Jack gently and repeat process, on the other side.
Once both wheel are up it will be a lot easier to inspect and replace properly.
Old 12-07-2012, 07:08 PM   #7
bmwbob89
My Ride: M-5 325 X3 528 740
You only need to replace the bad one. They are either good or bad.
bmwbob89 is offline   Reply With Quote
Old 12-07-2012, 09:38 PM   #8
Kubica
My Ride: 2003 325xi
^Ya if you bought your xi for $5k this year. Cheap bastards.
Old 12-07-2012, 11:46 PM   #9
e46alfonso
My Ride: 330xi MT, mustang gt
haaahhahahahahahahaa. I at this.
Old 12-08-2012, 12:10 AM   #10
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
...not really.
Op it's cheap. Replace the other one so you don't have to do it 2 months from now when it fails.
Old 12-08-2012, 09:36 AM   #11
kevin.john1
thanks all, will go ahead and do both while I am at it
Old 12-08-2012, 10:31 AM   #12
bmwbob89
You guys are pretty funny. If a dealer replaced both sides because one was bad you would all be saying they ripped you off. I replace what is needed when it is needed. They are not a part that needs replaced in pairs. The other one may last years before it needs replaced. It may have been replaced already. You can waste money if you like but i would rather spend it on things that actually need done or a beer.
Old 12-08-2012, 12:03 PM   #13
SamDoe1
^ So do you replace only one brake pad or rotor when the other side is good? How about shocks/springs?
If one side has failed, I would be willing to bet the other side isn't far behind.
Old 12-08-2012, 12:30 PM   #14
Rickna
My Ride: '01 330xi - '09 IS-F
+1 -It's also important for proper ballance.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 12-08-2012, 02:37 PM   #15
bmwbob89
They don't have any balance. Its a metal rod with a ball and socket. If the ball and socket are worn they make noise. You always do brakes per axle you don't replace front and rear because one axle is worn. Shocks are a little different. If they have more than 30k on them BMW says replace both if not do the one that is leaking. That was warranty criteria. I would always replace both shocks on the axles that were an issue if it was customer pay. I work on BMW's and have for almost 40 years. I know what I am talking about. If you don't want to listen that is your call and money. Don't tell other to spend what they don't have to.
Old 12-08-2012, 06:18 PM   #16
Rickna
I'm not talking about the links. Just argeeing with Sam on rotors, etc.
2001 BMW 330xi
2009 Lexus IS-F
Old 12-08-2012, 06:36 PM   #17
///MPR77
Like I said earlier, to fully inspect the part, it needs to come off IMO, and at that point, why not just replace it, 20-25 extra bucks for peace of mind, and a nice quiet clunk free ride.
I don't think anyone in this thread said that it was imperative to replace both, I know I didn't.
Old 12-08-2012, 08:09 PM   #18
bmwbob89
Almost every post said to replace them both. No need to remove them to check them. You pull up and down on them and if there is movement or the boots are torn they need replaced.
Old 12-08-2012, 11:42 PM   #19
Kubica
My Ride: 2003 325xi
Well if you want to be really cheap just run without front sway bar links.
Throw in some 87 from the no-name gas station and hit up pepboys for some Chinese tires.
I think you may be confused where you are. This is e46 fanatics. Note how it's not called e46 cheapskates or e46 hacks.
Best advice is to replace in pairs. Or sell and buy a chevy.
Old 12-09-2012, 01:44 AM   #20
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
though I am running fuzion uhp tires atm
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
anti roll bar links, sway bar links
