Old 12-09-2012, 02:14 PM   #1
Simon says
My Ride: 2003 BMW 325ci
Compression help needed
I am a new member, as well as a new member to owning a Bmw. I recently purchased and 2003 325ci and along with all the cars I come to own I want to deal them with as much care possible to get the most out of it. Is the 120 compression or i believe 9 bar each cylinder normal for my m56 SULEV engine? I believe normal compression is anywhere from 160-180 please correct me if I'm wrong but someone please help!
Simon says is offline   Reply With Quote
Old 12-09-2012, 02:28 PM   #2
aikmanson
My Ride: E30
Correct me if I am wrong here, but isnt the SULEV engine only offered in sedan form? Are you sure you have a SULEV engine, and if so, is your car really a 325ci?
1990 BMW 325is - Stroker Build
2010 MINI Cooper S
1995 Saab 900 SE - JZW Stage 4
aikmanson is offline   Reply With Quote
Old 12-09-2012, 02:39 PM   #3
Simon says
SULEV comes in 2003-2005 325 sedans, coupes, and sport wagons with automatic transmission only. I just don't know if it changes specifications from the m54 engine. It was confirmed by the dealership I was working with it has a SULEV
Old 12-09-2012, 05:25 PM   #4
aikmanson
My Ride: E30
Interesting, good to know.
I did a search on google and here and couldn't find any info on the compression of the SULEV. Found something that mentioned the pistons being different with the SULEV having a slightly lower compression ratio than the M54, but no hard numbers.
2010 MINI Cooper S
Old 12-09-2012, 06:43 PM   #5
shovelit
My Ride: 03 325xi and 04 330x
What prompted you to do a compression test?
Are you chasing a problem?
shovelit is offline   Reply With Quote
Old 12-09-2012, 07:20 PM   #6
lcoleman
My Ride: '79 Massey Ferguson
The exact number doesn't matter. Gauges can be inaccurate, or you might not have cranked it over long enough. It's the consistency between each cylinder that matters.
Old 12-10-2012, 12:04 AM   #7
Simon says
I'm not chasing a problem, I would just like to see the overall health and potential my at has to offer. I can't find anywhere on the Internet to what specifications may be different
Old 12-10-2012, 02:36 PM   #8
Hukerfaker
My Ride: My wife.
9 bars per cilinder should be normal compression on any petrol engine.
Hukerfaker is offline   Reply With Quote
Old 12-10-2012, 02:40 PM   #9
Hukerfaker
My Ride: My wife.
Now I see Wikipedia says 10, but I squeezed 200.000 kilometers out of my old car after I measured 9 bars per cilinder, so you should be fine. Just take care for the engine and don't treat it like it's m3
Old 12-10-2012, 02:45 PM   #10
WDE46
My Ride: '13 128i, '04 330Ci
The compression ratio is a little over 10:1, so you should see almost 10 bar. The rings and valves all leak a little bit even in perfect cars but not much.
Old 12-11-2012, 10:30 AM   #11
Simon says
Hmm, okay thanks to you all for this information
