Old 12-07-2012, 11:03 PM   #1
Steven747
My Ride: 05 330ci
Non -m electrical issue possibly voltage regulator
So my front right headlight as well as my center dome light in the cabin flickers when the car is on.. I checked the obc voltage and when the car is off it's 12v and when it's on it's 14v volts sound about right so does that rule out the voltage regulator ? Thanks. Also not sure yet what brand alternator I have yet
Thanks in advance
Old 12-07-2012, 11:11 PM   #2
Stinger9
My Ride: '04 330Ci
If you get a good 14v with the engine running, your alternator probably is not at fault.
That battery voltage is kinda low tho. How old is that battery of yours?
Old 12-07-2012, 11:15 PM   #3
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Would that actually cause the flicker? I noticed the same thing but with the lamp in the trunk.
HacksawMark is offline   Reply With Quote
Old 12-07-2012, 11:25 PM   #4
Stinger9
My Ride: '04 330Ci
Don't know for sure. Just know many report strange and varied problems with electrics when battery is old and started to fade.
How old battery?
Old 12-07-2012, 11:43 PM   #5
Steven747
My Ride: 05 330ci
Battery is old but no issues overall with it besides this stuff .. I do have a aftermarket amp.. So anyway to check battery life ?
Old 12-08-2012, 08:21 AM   #6
jgold47
My Ride: 2004 X5 3.0
aftermarket amp and subs can cause havoc with your car's electrical. BMW's seem to have this obnoxiously sensitive electrical system. I would start with a new battery. $100 bucks at wal-mart.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 12-08-2012, 10:25 AM   #7
Stinger9
My Ride: '04 330Ci
Simply +1
No way to 100% check old battery for what ails you. Already your test is that you only have 12v. That is low.
Model 49DL at Autozone is your best bet for larger capacity battery for great price. Do not ask them what battery is right for your car as they do not list this one.
Old 12-08-2012, 07:25 PM   #8
Steven747
My Ride: 05 330ci
Simply +1
12v when the car is off is low? what should it be? for what ive read it seems about right
ill check for loose connections tomorrow but i would imagine there would be more apparent issues. ill look into the autozone battery fursure though
Old 12-08-2012, 09:25 PM   #9
Stinger9
My Ride: '04 330Ci
Never seen anyone report voltage that had a good battery with less than a 12.4 or 12.6v reading.
Now 12v will get you by, but probably indicates that your battery is not the strongest, and has some age on it.
Old 12-08-2012, 09:52 PM   #10
pleiades
My Ride: M52TU
If it's right at 12 V that's actually marginal, somewhere between 25-50% state of charge. You want the battery to read about 12.5-12.6 V. If you drive the car every day, a good battery should be in the ballpark (assuming you have no sources of parasitic drain).
Your 14 V reading when running the car shows that the alternator is generating within spec and has the margin to charge the battery while powering everything (engine spark, all electrical systems, etc.), but what does it read when you have headlights and stereo going as well? If that amp is drawing a lot of juice, the alt might not have enough leeway to keep the battery charged.
pleiades is offline   Reply With Quote
Old 12-08-2012, 09:55 PM   #11
FenderGuy05
My Ride: 2002 BMW 325i
I had the same issue after installing amp and sub. Changed battery and it helped, but was told i should get a capacitor to be sure to prevent issues in future.
FenderGuy05 is offline   Reply With Quote
Old 12-08-2012, 11:28 PM   #12
Steven747
My Ride: 05 330ci
very interesting.
thanks to all who responded in this thread. all replys were very helpful..
so ignition in number 2 position voltage is a about 119 -120 with everything on .. if its not at the 12.5-12.6 could where its at now cause the smallest flicker and slight dullness of a headlight?
Old 12-13-2012, 09:49 AM   #13
Steven747
My Ride: 05 330ci
so guys new battery is in because mine died on me yesterday. dl49 or whatever it was from autozone.. no more cabin light flicker but my passenger angel eye still is dim and flickers....? found this other thread which sounds like the guy is having the same issue.. what do yall thing
http://forum.e46fanatics.com/showthr...ght=alternator
Old 12-13-2012, 10:34 AM   #14
Stinger9
My Ride: '04 330Ci
I'd suspect the size of the wiring to the angel eyes. Is it tiny stuff supplied by the manufacturer?
