Go Back   E46Fanatics > Everything Else > The Off-Topic > Health & Fitness
Health & Fitness
Discuss any topics related to heath and fitness here.
Closed Thread
Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average.
Old 02-04-2013, 11:28 PM   #81
z00
Banned User
My Ride: E46 M3 Manual
Ok, I was actually thinking whether to skip it or do it the next day. So Skipping is the answer. Any specific reasoning behind that?
Originally Posted by BMW_Matt View Post
FYI, if you ever do half a workout, don't finish it the next day. Just skip it until next week or until you cycle to that day again.
z00 is offline
Old 02-06-2013, 08:52 PM   #82
z00
Banned User
After some healthy pancake 1100 calorie meal, I had an awesome shoulders workout. Need to eat more.
Seated Military press
1 x 8 85lbs
2 x 8 95lbs
Standing behind head presses
3 x 6 90lbs
front wide raises
3 x 8 25lbs
side delts with palms in
3 x 10 15lbs
BB rows rear delts/trap
3 x 10 95lbs
inclined bench DB rear delts
3 x 10 20lbs
Tris/Bis superset
BB curls
3 x 8 80lbs
Close grip presses
2 x 8 105lbs
1 x 8 85lbs
z00 is offline
Old 02-07-2013, 11:01 PM   #83
z00
Banned User
Back
Deadlifts
1 x 6 225lbs
1 x 4 275lbs
1 x 2 295lbs
1 x 4 275lbs
1 x 8 225lbs
pull-ups 1 x 12 body weight
T-bar rows
1 x 8 100bs
2 x 6 110bs
21's
2 x 21 135lbs (7 reps of each: wide grip, close grip palms in, close grip palms out)
z00 is offline
Old 02-11-2013, 12:54 AM   #84
z00
Banned User
Chest
Incline DB press
2 x 5 65lbs
1 x 6 65lbs
BB bench press
3 x 5 155lbs
Dips with 30lbs
1 x 15
2 x 11
Pushups with 30 lbs
1 x 8
1 x 6
Cable flies
3 x 10 40lbs
Cable presses with palms out
3 x 10 60lbs
Abs with 30lbs:
planks, 2 x 35sec
Bench crunches 2 x 8
Leg ups 2 x 15
z00 is offline
Old 02-11-2013, 02:18 AM   #85
bostonsc4
My Ride: BMW 323i
Originally Posted by z00 View Post
Chest
Incline DB press
2 x 5 65lbs
1 x 6 65lbs
BB bench press
3 x 5 155lbs
Dips with 30lbs
1 x 15
2 x 11
Pushups with 30 lbs
1 x 8
1 x 6
Cable flies
3 x 10 40lbs
3 x 10 60lbs
Abs with 30lbs:
planks, 2 x 35sec
Leg ups 2 x 15
Sounds like a solid past few days! Nice work on the deadlifts, those are some pretty good numbers.
bostonsc4 is offline
Old 02-11-2013, 10:20 AM   #86
z00
Banned User
Deadlifts and front squats have been improving fast (adding about 5 lbs every 1-2 weeks) but the rest of exercises are improving about 3x slower. Which kills motivation.
z00 is offline
Old 02-11-2013, 10:42 AM   #87
DylloS
My Ride: nothing
that's typical. If you could add 5lbs every week you'd be benching and curling 400lbs in a matter of a year.
DylloS is offline
Old 02-11-2013, 11:15 AM   #88
dabears
My Ride: 2003 BMW M3
yeah that shouldn't be killing your motivation, you might need to lower expectations. As long as I am making progress in some form week in and week out I am happy and continue to stay motivated.
If I don't make progress, I get pissed off and even more motivated to eat more and lift better.
dabears is offline
Old 02-11-2013, 03:31 PM   #89
z00
Banned User
I feel that my chest is my weakest link, With DBs I do 70lbs (each hand) 6 times. On BB total of (with bar) 155lbs 5 times. Compared to my deadlifts, squats, and pull-ups it does not make sense. Maybe because I have long arms but I don't like to make up excuses for not improving. I guess having high expectations does not help either. In last 2 months I see good changes in my body comps, I'll upload some pics after work.
z00 is offline
Old 02-11-2013, 03:40 PM   #90
dabears
For comparison sakes (and we have similar body type, long arms etc)
My current 5 rep maxes
Bench : 175 x 5
Squat : 235 x 5
Deadlift: 290 x 5
I've easily spent the most time working out my chest over the years, either from skipping workouts or being dumb etc. Spent the past few months catching up squats & deadlifts, they are at a decent point now.
It usually takes me a couple weeks to move up 5 lbs in barbell bench press where I can at least 5 reps. Where as with deadlifts and squats I'm going up almost every week.
As long as you see progress (# of reps or weight going up) that means you are getting stronger. Numbers are strictly arbitrary.
dabears is offline
Old 02-11-2013, 03:47 PM   #91
DylloS
My Ride: nothing
just curious what arm size your guys dress shirts are. Mine are 34/35. Would that be "long". Not like I care. I'm just curious since I'm in the same boat as you guys in terms of bench strength.
DylloS is offline
Old 02-11-2013, 04:10 PM   #92
z00
Banned User
Bench : 175 x 5
Squat : 235 x 5
Deadlift: 290 x 5
You weigh 180lbs right? I'm 164lbs, 5'11.5". Our numbers are very close, I'm higher on deadlifts, you're higher on bench, we're the same on squats. This explains it, I just started doing BB bench press, it was all DBs. I feel that my shoulders get worked out more on BB. I prefer DBs, but it's good to do some BB to change up the workouts.
I see progress, but I guess it's slower than what's expected. Having expectations is a bad idea in life.
It's tricky to base arms reach on dress shirt size. I wear Fitted Express small size, Armani Med, not sure how that compares to 34/35.
If you stand straight, put your hands flat on side of your thighs. My fingertips are about 6.2 inches above my kneecap.
Another way is to measure your horizontal width, stand with arms raised shoulder level, measure distance from the middle fingertip on one hand to the other. Compare the result with your height and check the ratio.
z00 is offline
Old 02-11-2013, 04:28 PM   #93
dabears
Yeah, I just broke 180 last week. I don't think you can say 295 x 2 is higher than 290 x 5 (if that's what you were referring to); haven't seen a squat number from you lately so can't compare that. Have you really moved up from 175 x 4 to 235 x 5 in the past two months? That's impressive
What shoulder work have you been doing?
I'm at roughly 15% bf right now so 153 lbs of lean mass for comparisons sake.
dabears is offline
Old 02-11-2013, 04:30 PM   #94
DylloS
My Ride: nothing
just measured mine. 6.5-7" from my knee cap
DylloS is offline
Old 02-11-2013, 04:40 PM   #95
dabears
I'm 6" just measured as well. luckily I don't look "lanky" but I definitely have long arms and legs. I blame my shoulders being weaker than chest for my less than stellar bench performance moreso than longer ROM.
dabears is offline
Old 02-11-2013, 04:42 PM   #96
DylloS
My Ride: nothing
yea I dont blame my arms for anything. If I can't lift it I can't lift it. There is no class for longer armed people lol.
DylloS is offline
Old 02-11-2013, 04:59 PM   #97
z00
Banned User
My number was from smith machine squats which cannot be compared to BB squats. So I take that back I have not tried my max 5 on BB squat, I'll be doing 145lbs x 15 on next legs day
My front squats jumped from 95lbs to 135lbs in 2 months. You have 16lbs over me, so you better be lifting more than me
I just took this pic on my rest day and after eating 1lb of chicken + 1lb of veggies, I think I'm down to 13BF. Just guessing as I did not measure it. When my stomach is not full I see 4 top abs lol
My goal is to gain 6 lbs of muscle by end of spring. I don't think I'm eating enough, and my food is too clean.
z00 is offline
Old 02-11-2013, 05:06 PM   #98
dabears
Yeah that's why I was surprised, since I have more weight.
Stop guessing and start tracking. Its realistically the only way to start understanding just how many calories you are getting. I believe everyone should do this to learn what makes up the foods you eat... it sets you up for a lifetime of success.
What's going to be a bigger waste of time, the 5 minutes a day it takes to track your food or the weeks & months you wasted working out and not eating enough to create growth?
You can make great gains on "clean" food, but you need to eat a LOT of it. Something most people would have difficulty doing.
dabears is offline
Old 02-11-2013, 05:12 PM   #99
z00
Banned User
I did track via my phone for a couple of days. Then once I realized how much food I need I stopped tracking and kept following the same calories needs. But I think 3100 on workout days, 2600 on rest days are too low for me. I tried a couple of different calorie calculators and these are numbers I get. I'm afraid if I eat more than that I'll get fat. My stomach is sensitive with IBS so I'm forced to eat clean food. I get 200g of protein a day, 75% of it from natural foods (meat, chicken, seeds/nuts, and fish). Rest of it from protein powder.
Do I have an ectomorph body type?
z00 is offline
Old 02-11-2013, 05:19 PM   #100
dabears
Why do you think 3100 calories is too low for you? You are seeing strength gains correct? What is the issue?
No based on your pics there is no way you are an ectomorph. I know several ectomorph's personally and you don't match the bodytype.
It is possible to be a mix of the three body types, but I think you aren't getting the calories you think you are (or tracked them incorrectly).
dabears is offline
Closed Thread
Rate This Thread
