Sponsored by BAVSOUND
Old 12-13-2012, 05:18 AM   #1
KaziKai
My Ride: 2001 325i
Unhappy Business CD Radio Show WAIT
I bought this CD53 R50 2003 November from ebay.
Was messing around with the PA Soft 1.4.0 on my 2001 325i and Accidentally hit the rest for the radio.. now it shows only WAIT.. How do I get it out of the WAIT mode and how can I get the Radio CODE?
S/NO: AL 5011 3 11 44280
P/NO 65.12-6 934 347
SW/NO. 45
HW/NO. 42
KW: 45/03
AI: 01
Alpine Made in Hungary
Or can some help me get a code? Stealership wants $245USD for the unlock code...
But my first part is how do you get it out of WAIT? Its been on wait for 2 days...
KaziKai is offline   Reply With Quote
Old 12-13-2012, 06:10 AM   #2
jfoj
My Ride: 330CiC, M5, X5
Disconnect the battery for at least 30 minutes or pull the radio fuses and see what happens?
Old 12-13-2012, 06:15 AM   #3
KaziKai
My Ride: 2001 325i
Pulled the fuse out and nothing ill try the battery for 30 mins
Old 12-13-2012, 04:17 PM   #4
KaziKai
My Ride: 2001 325i
battery did not work.. still shows WAIT I did however change back to my not working so good old radio and it works.. so I guess its just the radio locked... looks like im going to have to contact bmw if I cant get this fixed some how... my old radio volume thing is broken when you turn a lil it goes up to MAX till im deaf! unless there is a way to fix that with my locked radio it be great...
Old 12-13-2012, 04:18 PM   #5
KaziKai
My Ride: 2001 325i
and the other reason y I did the swap is cause I want the MODE button...
Old 12-14-2012, 04:01 PM   #6
KaziKai
My Ride: 2001 325i
Bump
