Old 11-23-2012, 10:06 PM   #1
Hovs13
My Ride: E46 325ci
idle fluctuates when rear defroster actived
When weather is less than +5C, I notice my idle fluctuates up and down between 500-1000rpm after turning on the rear defroster.
does this happen to anyone else?
Hovs13 is offline   Reply With Quote
Old 11-23-2012, 11:36 PM   #2
cityjohn
My Ride: 2001 M3
It's common for RPMs to drop when the alternator is under load
cityjohn is offline   Reply With Quote
Old 11-24-2012, 12:06 AM   #3
MercForHire
My Ride: M235i 6MT
2.5 engine is too weak
Old 11-24-2012, 02:04 AM   #4
MJLavelle
My Ride: 2001 BMW 330ci
It will probably do the same thing if you press the window switch to raise the window, when the window is all the way up too. It is just the load on the alternator, like they said above.
Old 11-24-2012, 10:03 AM   #5
Hovs13
My Ride: E46 325ci
Perhaps I didn't explain it well. the RPM drops then rises, then drops, then rises... in a continuous cycle until engine is warmed up completely or rear defroster is shut off.
This used to happen to my car even when engine was warm but recently cleaned the idle control valve and it solved this issue when engine is warm, but it continues to happens when engine is cold.
Old 11-24-2012, 10:29 AM   #6
shovelit
My Ride: 03 325xi and 04 330x
Weak battery? The alternator just maintains the charge of the battery. If the battery is weak it could be discharging quickly causing the alternator to cycle like that. Just a guess but worth a look.
shovelit is offline   Reply With Quote
Old 11-24-2012, 08:16 PM   #7
MJLavelle
That is just the rear defroster cycling on and off. It does not stay on constantly. It is most likely still the rear defroster. And it does not have anything to do with a 2.5l engine. My 330 does this as well.
Now, it may mean that the alternator is getting old, but mine has done it for 3 years with no charging problems. I think this is normal for a lot of cars. Both of my e46's have done this.
Old 11-26-2012, 05:13 PM   #8
Hovs13
My Ride: E46 325ci
Again I've had this issue for years. It used to happen when car was warm and cold but since i cleaned the ICV it only fluctuates when engine is cold.
does the defroster cycle on and off every second? because that is roughly the timing of the rev fluctuations.
I'm not worried, just curious about others experiencing this.
Old 12-08-2012, 06:14 PM   #9
Hovs13
My Ride: E46 325ci
Any other thoughts?
Old 12-08-2012, 06:58 PM   #10
FenderGuy05
My Ride: 2002 BMW 325i
If the ICV helped in warm weather, have you taken a look at ensuring there aren't vacum leaks? Checked out jfoj's thread on weak or irratic idle?
FenderGuy05 is offline   Reply With Quote
