General Off-Topic
Old 12-08-2012, 09:56 PM   #1
NFRs2000nyc
My Ride: 2003 FormulaRedS2000
Snow belt guys, recommend a snow brush.
Figured some of you guys would know of a good snow cleaning brush that won't scratch the paint, any advice?
NFRs2000nyc is offline   Reply With Quote
Old 12-08-2012, 10:13 PM   #2
Grande D
My Ride: zhpppppp (o-m-g!)
Huh? They all will- sorta. Like swirls marks. Just use a glove to brush the snow off paint and a scraper for the windows.
If you wanna get really anal about it maybe boars hair? I take swirl marks and scratches seriously- but I don't think any brush will be soft enough.
Old 12-08-2012, 10:15 PM   #3
Fergo_the_mule
My Ride: S52 E30(dead)08 135i
Anything abrasive enough to take snow off will most likely scratch the paintwork.
Originally Posted by Steven747 View Post
v10 was awesome new m5 is just fast dosent have a soul just 2 easy to make hp turbos
Fergo_the_mule is online now   Reply With Quote
Old 12-08-2012, 10:19 PM   #4
kuksul08
My Ride: M3
Send a message via AIM to kuksul08
spray it with the hose
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
kuksul08 is offline   Reply With Quote
Old 12-08-2012, 10:25 PM   #5
NFRs2000nyc
Damn. I thought there would be some silicone miracle brush but I guess not. Thanks anyway fellas.
Old 12-08-2012, 10:28 PM   #6
Grande D
What I do is usually knock off most of the snow but not the last .5" or so. That way you will never come in contact with the paint directly.
Old 12-08-2012, 10:35 PM   #7
NFRs2000nyc
That's my general technique as well. The last little bit I just let the ambient heat take care of it.
Old 12-08-2012, 11:09 PM   #8
farmdog
My Ride: Acura TL
Use a leaf blower.
farmdog is online now   Reply With Quote
Old 12-08-2012, 11:11 PM   #9
v8 5
My Ride: 6 speed BMW
if you had a 2jz you really wouldn't have this problem
Gutted with a Getrag
v8 5 is offline   Reply With Quote
Old 12-09-2012, 01:34 AM   #10
peytonracer4
My Ride: '00 328i
G A r A g E
Or just brush all but 1/2" off and then drive 50 mph and it will blow off.
you do know that it will blow off right?
choose to click or forever hold your piece ;)
Old 12-09-2012, 08:43 AM   #11
TJ710
My Ride: 2002 325i
It won't always blow off. It depends on the moisture content of the snow and the outside temp
5 Speed. 3.46 Diff. Shark. Koni. H&R
TJ710 is offline   Reply With Quote
Old 12-09-2012, 10:05 AM   #12
peytonracer4
My Ride: '00 328i
True. If he's that concerned it should be garaged ya know? Snow isn't a big deal.
A hose will get it off. But he'll need to drive it directly after because it'll freeze all the doors shut and stuff.
Old 12-09-2012, 10:19 AM   #13
Grande D
Hosing down a car in near freezing weather is a positively awful idea.
Old 12-09-2012, 10:22 AM   #14
peytonracer4
My Ride: '00 328i
Not really. Maybe at zero degrees. But water takes a while to freeze. It will also freeze in a very thin layer that will just fall off.
Haven't you ever had snow on something and used water to eliminate it? It works really well.
But that's why I recommend driving right after it gets sprayed.
Old 12-09-2012, 10:33 AM   #15
Locutus09
My Ride: Something Slow
None exist.
Locutus09 is offline   Reply With Quote
Old 12-09-2012, 10:36 AM   #16
SurreyF1
My Ride: BMW
meh, in the sun and if you drive it right away, you are fine. i would be more worried about my drive way becoming an ice rink by the time i get home however...
SurreyF1 is offline   Reply With Quote
Old 12-09-2012, 12:41 PM   #17
TayloMade[07]
My Ride: '12 Frontier Pro-4x
all you really need to scrape is your windows, like it was said the rest will all just blow off. or wash it. I washed my truck yesterday, and it was -20C, no big deal just have to run the command start a few minutes and let the weather stripping warm up. not sure what you guys have to go through in the winter, but here they are always putting salt/gravel down, so i usually try and wash my car more in the winter then I do in the summer sometimes, having all that salt sit on your truck is worse then gravel/mud imo.
[Instro.Mental]
Old 12-09-2012, 12:46 PM   #18
tock172
100% star stuff
tock172's Avatar
My Ride: 2004 330i
How about the original BMW one?
http://www.ecstuning.com/BMW-E46-330.../Ice/ES194649/
Bilstein/Eibach B12 Pro-Plus Suspension & Sway Bars | DICE Mediabridge | Valentine One
tock172 is online now   Reply With Quote
Old 12-09-2012, 11:24 PM   #19
Fisch330ciTopasBlau
Yes...I do think I hate you
Fisch330ciTopasBlau's Avatar
My Ride: A car.
http://www.thinkgeek.com/product/ec0...0ice%20scraper
-8/21/2007 RIP Grandma
-pessimum genus inimicorum laudantes: flatterers are the worst type of enemies
Fisch330ciTopasBlau is offline   Reply With Quote
Old 12-10-2012, 09:34 AM   #20
SamDoe1
My Ride: 2004 330xi, 3 pedals
^ This.
Scrape windows, don't mess with the painted panels or use your hand to push most of it off.
I usually try to use a touchless wash (gasp!) in the winter so that I can get the underbody wash.
