Old 12-08-2012, 11:04 PM   #1
alexb18
My Ride: 04 325Ci
New Idler Pulley wobble?
2004 325
Replaced the tensioner pulley and idler pulley today... seems to wobble a bit when idling. Also there's a slight clicking noise that seems to come from it.
Is this normal?
alexb18 is offline   Reply With Quote
Old 12-08-2012, 11:15 PM   #2
Steven747
My Ride: 05 330ci
did you tighten the bolt fully?
Old 12-08-2012, 11:24 PM   #3
alexb18
My Ride: 04 325Ci
I tightened it to about 20ft-lbs before I put the belt on... I'm taking it off, checking it out, and putting it back on at the moment - waiting for the engine bay to cool a few degrees, it's an inferno right now
It seems like the issue is the bearing having some play, not the spacer behind it not being locked down properly. Can anyone check to see if theirs is doing the same thing? Could always be a bad part from advance...
Old 12-08-2012, 11:30 PM   #4
alexb18
My Ride: 04 325Ci
Update: I took the pulley out, set it flat on my desk, and I can wobble the shaft around the bearing just slightly.
Old 12-09-2012, 12:22 AM   #5
alexb18
My Ride: 04 325Ci
I put the old one in and it doesn't wobble... I'll take this new one back. On that note, the BRAND NEW tensioner pulley is also leaking grease. I guess they don't make them like they used to :-\
Old 12-09-2012, 12:59 AM   #6
pocojo68
My Ride: 2004/320i
What brand was it. INA?
Sent from my LG-P500h using Bimmer App
pocojo68 is offline   Reply With Quote
Old 12-09-2012, 01:01 AM   #7
alexb18
My Ride: 04 325Ci
Dayco... I'm thinking of just repacking the old bearing and calling it good. Seems like the old ones have significantly less play (almost none) than the new ones.
Old 12-09-2012, 01:03 AM   #8
alexb18
My Ride: 04 325Ci
Actually the parts themselves say "Flennor Germany"
Old 12-09-2012, 02:29 AM   #9
TonyJ
My Ride: E46 330i
German build quality is no longer the golden standard. I have recently replaced a perfectly working original water pump with a brand new Bosche one, as a PM. Its impeller shattered in just a few month. It caused more damage than it supposed to "fix". Go figure.
I'm now no longer throwing new pieces blindly just to PM. I have no issues with VCG, OFHG, CCV, so no way in hell will I touch these part, until oil leaks.
TonyJ is offline   Reply With Quote
Old 12-09-2012, 02:33 AM   #10
SteadyMobbin
My Ride: ImolaZHP 6spd M/T
I have read that bosch makes questionable water pumps. If you go with oem for parts you should be fine...
SteadyMobbin is offline   Reply With Quote
Old 12-09-2012, 02:42 AM   #11
alexb18
My Ride: 04 325Ci
Things I've learned in this process...
I ended up reusing my older idler pulley (worked fine, not noisy, still feels full of grease)... definitely needed a new tensioner pulley though. I assume since both sides of this tensioner pulley bearing leaked a bit, it's due to the break in process where the centrifugal force pushes out a bit of grease, particularly when it warms up. The wobble on the Dayco idler pulley, however, was completely unacceptable and I will return that. There can be some play when you test it out with no tension, but once tensioned, this noisy wobble is no bueno.
Old 12-09-2012, 07:41 AM   #12
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Buy the INA pulley which is OEM.
Old 12-09-2012, 07:48 AM   #13
tommy d
My Ride: 2005 330i
+1, I just replaced my Tensioner and Idle pullies with INA brand and no issues.
Current Vehicles in my stable:
2005 BMW 330i - 94K miles
2005 Mazda Tribute s - 89K miles
1998 Ford Taurus SE - 103K miles
1987 Ford Mustang LX 5.0 - 230K miles
tommy d is offline   Reply With Quote
