Sponsored by BimmerWorld
Old 12-09-2012, 02:21 AM   #1
steveintheburgh
My Ride: 2004 330Ci
Lube your Poly CABs before install
I found this info deep in a few strings---thought it would be good to have a post specific to it.
As a far-from-pro internet-trained gearhead, I wrongly assumed my Polyurethane CABs were plug and play. (Mine were from EAS)
2 weeks after install the creaking started and progressively got louder. Researched here and duh......grease is key.
Not a huge deal to do them on the car...The bracket on mine slid very easily off of the insert (slide it towards the rear of the car). Grease the outside of the insert and inside of the sleeve and you're good to go.
Probably should have been obvious....hopfully my error is someone's gain.
steveintheburgh is offline   Reply With Quote
Old 12-09-2012, 03:14 AM   #2
illestminimike
My Ride: Project Drama
Most of them come with the grease. At least powerflex does. I haven't had any creaks or squeaks.
Old 12-09-2012, 05:59 PM   #3
Alex323Ci
My Ride: M3 & 323Ci (sold)
you'll find this info listed in depth on this thread on the install. you should use it on everything of the bushing that touches metal. many of us use the copper anti-seize
http://forum.E46Fanatics.com/showthread.php?t=678004
Old 12-11-2012, 08:48 AM   #4
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Does the grease ever wash off or otherwise come off over time? Is periodic re-greasing necessary for PU bushings?
Old 12-12-2012, 04:30 AM   #5
steveintheburgh
My Ride: 2004 330Ci
pics of the brand that didnt have any lube...and getting to what needed lube
ID:	481805   Click image for larger version
