Old 12-09-2012, 09:19 AM   #1
76m2002
My Ride: 2002 325iT
Ball Joint separator?
Has anyone found a good tool for removing ball joints? I want to reuse the ball joint on my e46, so don't want a pickle-fork, and don't want to use a torch. I tried smacking the control arm with a BFH, but could not get the ball joint to drop from the steering knuckle. I tried the the Horror Freight ball joint separator (http://www.harborfreight.com/3-4-qua...tor-99849.html), but it wore out after removing one tie-rod. The threaded driving bolt for the HF tool started grinding into the soft metal of the receiving arm of the tool, instead of forcing the two arms apart. This is for an outer ball joint in a control arm of a 325xiT, so I don't have much room over the top of the threaded rod of the ball joint, and can't use the larger tools that look like giant "C" clamps.
Thanks for any suggestions.
76m2002 is offline   Reply With Quote
Old 12-09-2012, 05:53 PM   #2
MINIz guy
My Ride: bro truck
Did you soak the ball joints in some type of penetrating oil?
I've used that same tool for ball joints on an E39 and it worked fine. I did soak my ball joints in WD40 for at least 20 minutes and the joints just popped out without much pressure at all.
MINIz guy is offline   Reply With Quote
Old 12-09-2012, 08:40 PM   #3
TurnersInOz
My Ride: 2004 325i
+1 on soaking.
When I did my FCAB's I beat the heck out of the outer and it just wouldn't budge. Soaked it with some oil, let it sit over night and it came right out.
TurnersInOz is offline   Reply With Quote
Old 12-09-2012, 09:15 PM   #4
76m2002
My Ride: 2002 325iT
Soaking didn't with penetrating oil didn't help. Must have been 10 years of salty NE winters. I ended up removing the control arm/steering knuckle assembly intact instead.
Old 12-11-2012, 08:56 AM   #5
Brobby87
My Ride: 2003 325i, 1986 535i
I can attest to this tool being absolute crap. Same thing happened to me.
Luckily I was upgrading my control arms to the ZHP kind so I didn't care if I shredded the old ones. Just used a pickle fork, hammer, and a good soaking like mentioned above.
Brobby87 is offline   Reply With Quote
