Sponsored by BAVSOUND
Old 12-09-2012, 11:50 AM   #1
sdbyrd
My Ride: 2001 325i
Stock Amp Bypass Cable?
Does anyone know where I can buy or have a custom cable made that bypasses the factory amp so I can run everything from my head unit? I realize I can do the pin outs and hand splice them all, but I would rather use a premade cable if possible. This would be for a 2001 325i non-Nav non-HK.
sdbyrd is offline   Reply With Quote
Old 12-09-2012, 04:35 PM   #2
markusmarkus
My Ride: 2001 330Ci
I've never seen an adapter. Every conversion - oem amp to aftermarket amp - required cutting and splicing of the wires. I did it. It's not fun especially lying on my side in the cramped trunk.
Old 12-09-2012, 06:54 PM   #3
Grande D
My Ride: E36 M3
There is a harness.
http://www.e46fanatics.com/forum/sho...d.php?t=793352
You could just twist/solder the head unit outputs to the speaker wires.
It will change your life!
Old 12-09-2012, 09:26 PM   #4
markusmarkus
My Ride: 2001 330Ci
The head unit has no amp. The head unit's output is balanced differential line level signals.
Old 12-10-2012, 12:17 AM   #5
WillC310
My Ride: 10 E90M3
I had one when I had my E46M3. You need to find a donor amp to hack apart and make one.
WillC310 is offline   Reply With Quote
