Australia
Old 12-10-2012, 07:22 AM   #1
figjam911
My Ride: 1999-323i
Where can I get my Codes Read in Melbourne
My 323i- 1999 is not running right...
I changed the camshaft sensors and am running with the exhaust camshaft sensor unplugged as it is the only way it will run properly without roughness, missing and stalling. Cleaned everything, new fuel filter, new fuel pump.
What is wrong with it?
Where can I get the codes read in Melbourne guys?
And what sort of code reader can I buy to get BMW codes, if any?
Thanks in advance!
Colin
1999-323i Steel Grey, black leather, CD stacker, tinted windows, reversing radar, sunroof and Pirellis on M-Sport 17" alloys, 245 mm wide on rear and 225 mm wide on front.
Colin Boucher
figjam911 is offline   Reply With Quote
Old 03-03-2013, 08:27 PM   #2
N4NOOK
My Ride: 323ci
Hey Colin,
Did you ever get this resolved?
I am experiencing the same thing with mine.
Had codes read, replaces the camshaft intake sensor, camshaft exhaust sensor, maf blah blah blah still car is being a **** head.
Cheers,
Tim
N4NOOK is offline   Reply With Quote
Old 03-03-2013, 09:39 PM   #3
figjam911
My Ride: 1999-323i
Hi Tim,
I chased all the symptoms to no avail...couldn't find anyone to read the codes because the excuse was too busy, and those that did wanted between $150 - $310 to do it and you and I know it takes about 5 minutes maximum.
So I bought a Peake code reader from the 'good Ol' USA' and 'bingo', read the instructions, 3 minutes max, after plugging it in about 3 minutes after all the codes there, just look up the book. Another 2 minutes. My problem was pin pointed to a missing coil on #1 and #2, it played up intermittently. Changed those and bingo again...all OK.
If you want to PM me, you can drop by my place in Armadale and we'll plug it in for you and read them again. Takes 5 minutes!
Cheers,
Colin
Colin Boucher
Old 03-04-2013, 03:23 AM   #4
helrot330ci
I have a full bmw diagnostic scanner and can clear any codes.
E46 has seperate modules for engine, abs/dsc, srs airbags etc.. I can diagnose all modules also for other models, e36/46/39/60 , e90/92/93 , x3/5/1. And all 1 series
Pm me im in melb
helrot330ci is offline   Reply With Quote
Old 03-04-2013, 03:40 AM   #5
figjam911
My Ride: 1999-323i
Helrot330i...
I did all my codes and cleared them all after the Peake tool told me what was wrong!
Best thing I ever did buying a code reader...so easy...all info at your fingertips.
Change the part...check again...no fault codes. Easy!!! Runs like a dream!
Oh! Meant to say...my 323i has the 16 pin connector...the Peake tool came with a OBCD rectangular plug conversion...but I've misplaced it. Need to find it ! It is here somewhere!
Colin
Colin Boucher
Old 03-04-2013, 04:20 AM   #6
figjam911
My Ride: 1999-323i
I found the OBCD plug conversion...
Colin Boucher
