99 323i P1182 code help?? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-12-2012, 05:23 AM   #1
Baro1220
My Ride: 06 530i sport 6speed
I had P1182 code come on and i would reset it
and it would come on after 10min of driving...
I found that i could be o2sensor or maf.
so i cleaned my maf. Reset it took it for ride and and it and it came back
on after an hour.... So do yoy guys think its a bad maf.
or i should still do the o2 first??
Thanks...
Baro1220 is offline   Reply With Quote
Old 12-12-2012, 05:35 AM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Not sure I would replace any sensors yet.
Read the first 2 links below in my signature first.
Old 12-12-2012, 11:26 AM   #3
jdstrickland
My Ride: '94 325iC & '00 323i
Thanks...
P1182 O2 Sensor (Bank 1 Sensor 2) Open Circuit During Coast Down Fuel Cut-off
P1183 O2 Sensor (Bank 2 Sensor 2) Open Circuit During Coast Down Fuel Cut-off
I cannot see the MAF as part of the problem for these codes. They are for Sensor 2, which is the After CAT sensor. The O2 Sensor costs $100-ish, the MAF (which is not part of your symptom set) runs about $300. You decide.
Old 03-26-2013, 01:42 PM   #4
texlnghorn
My Ride: 330ci
I have been chasing the P1181 and P1182 codes for awhile now. These are the pre-cat O2 sensor fuel trim fault codes. I have replaced the uppper and lower intake boots (both had tears), ccv and 4 hoses (all looked fine but i know it is a common cause for these codes), Vanos Oil Line (it was leaking badly), and the valve cover gasket (because I have an oil leak), but the codes kept coming back within minutes of driving. I finally took it to a mechanic and he stuck on a new MAF and the codes stayed off. So I bought the MAF for $240. However after 4 days of driving P1182 came back all by itself without P1181. I'm thinking that I should just go ahead and replace the pre-cat O2 sensors. Anyone other ideas?
texlnghorn is offline   Reply With Quote
Old 03-26-2013, 02:11 PM   #5
B Potter
My Ride: 01 330
Did you clean the idle control valve and the throttle body while you had the lower intake boot off?
B Potter is offline   Reply With Quote
Old 03-27-2013, 08:03 AM   #6
texlnghorn
My Ride: 330ci
I cleaned the throttle body and disa but not the iac valve. But why would this cause p1182 and not p1181 also? For more than 6 months I have had both codes and after changing the maf, now I only have p1182.
Old 03-27-2013, 10:52 AM   #7
Baro1220
P1182 for me ended up being bank1 sensor 2
No problem since
Old 03-27-2013, 11:19 AM   #8
dslboomer
My Ride: 2001 BMW 330I
These are the code description from the Bentley manual.
They are post-cat sensors not the pre-cat.
O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 2)
If you want to do proper diagnosis of O2 sensors, look at this.
My bet is bad post-cat o2 sensors based on age of our cars if they are not replaced before.
http://http://forum.e46fanatics.com/showthread.php?p=15288760#post15288760
dslboomer is offline   Reply With Quote
Old 03-27-2013, 11:20 AM   #9
texlnghorn
My Ride: 330ci
No problem since
I'm confusing myself. I had been chasing P1188 and P1189 until I replaced my MAF. Now I have P1182 which is new since replacing the MAF. Sensor 2 is the post-cat O2 sensors? Did you replace both or just bank 1? Is bank 1 the closest to the cat?
Old 07-06-2013, 09:08 AM   #10
DunnDem
My Ride: E46 1999 323i sedan
p1182
did you ever got rid of that p1182 code...this code is driving me crazy...i changed the o2 sensor..still no luck
DunnDem is offline   Reply With Quote
Old 07-06-2013, 09:27 AM   #11
willsbma
My Ride: 99 323i
Unplug maf and drive for a few minutes, see if you get a different code?
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 07-06-2013, 10:50 AM   #12
DunnDem
p1182
P1182 ..help...I have changed
02 sensor bank 1 sensor 2
Lower and upper intake boots
Fuel filter
Spark plugs
Im starting to think I changed the wrong 02 sensor...car runs great though
Bmw world help before I buy a honda hahahaaha
