Old 12-09-2012, 03:39 PM   #1
Ruthlessone3k
My Ride: 323i
humming/buzzing sound when ignition turned on
Ok, as the title states there is a humming/ buzzing sound that comes on when I turn the key to the on position, even without the engine running. The noise will continue for several seconds after I remove the key. Once again without ever turning the engine on. It seems to be coming from the driver side of the engine below the intake back toward the firewall. Any ideas what could do that. Is it normal?
Ruthlessone3k is offline   Reply With Quote
Old 12-09-2012, 04:31 PM   #2
TT330i
My Ride: 2003 330i
Interesting observation. I think it's normal because mine does it as well, but I have no idea what it is.
TT330i is offline   Reply With Quote
Old 12-09-2012, 04:52 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
Is it kind of a "brrrrrrrr" noise for a second or so? Mine does it randomly if I have lights on and the key out of the ignition, I have no clue why. It sounds like it's coming from my instrument cluster.
Old 12-09-2012, 04:59 PM   #4
quiksilver4drM3
My Ride: 330ci
Its the fuel pump priming before you actually start the engine. Just getting the fuel to the motor
quiksilver4drM3 is offline   Reply With Quote
Old 12-09-2012, 06:17 PM   #5
TT330i
My Ride: 2003 330i
No to both of these. It's a buzzing coming from under the intake manifold with the key in the on position. It doesn't stop as long as the key is on.
Old 12-09-2012, 07:27 PM   #6
lmr2wil
My Ride: '00 328Ci
I don't know for sure what your sound is. I do know that the DME has a cooling fan that sits near the region you're describing. Could it be that running?
Edit: See #5 - http://www.realoem.com/bmw/showparts...99&hg=12&fg=35
Luke
lmr2wil is offline   Reply With Quote
Old 12-10-2012, 12:35 AM   #7
Ruthlessone3k
My Ride: 323i
Exactly! I don't know what it is, but it doesn't seem normal.
Old 12-10-2012, 07:31 PM   #8
BobbyC
My Ride: 2000 328I
Are you sure that the coils are not firing for a little bit??? I know for a fact that on some saabs the ignition fires 3-5 seconds or so after you turn off the car. It also fires before you turn on the car. Something to do with cleaning off the spark plugs. Don't know if BMW has this feature, have not heard it on my.
BobbyC is offline   Reply With Quote
Old 12-10-2012, 07:52 PM   #9
AfghanScarface
My Ride: Debadged M3
Send a message via AIM to AfghanScarface
Its normal. Every BMW ive owned does it. I don't know what it is though
Originally Posted by Bimmer4Lyfe View Post
Either pursue her and risk getting Mono, or don't pursue her,...stay home and use your Mano.
It's either Mono or Mano .... You decide
AfghanScarface is offline   Reply With Quote
Old 12-10-2012, 07:54 PM   #10
Nico16
My Ride: 2000 323i
Heater?
Nico16 is offline   Reply With Quote
Old 12-10-2012, 09:16 PM   #11
mxchris727
My Ride: E39, E93 335
Send a message via ICQ to mxchris727 Send a message via AIM to mxchris727 Send a message via MSN to mxchris727
It's the throttle body. All of my BMW's make the same sort of noise.
-Chris
I have a computer set up with DIS, TIS, SSS Progman, INPA, NCS Expert, WinKFP, and Tool32 with an EDIABAS interface; PM me if you want to stop by and code your car.
ISTA/P & /D is up and running!
mxchris727 is offline   Reply With Quote
Old 12-22-2012, 01:21 PM   #12
Ruthlessone3k
My Ride: 323i
I finally found it! It is coming from the idle regulating valve.
Old 12-22-2012, 02:39 PM   #13
cyberkaa
My Ride: E46 332i,M3;E30 325i
Absolutely normal. Yes, it's the ICV.
-Kalim
(klx photo studio)
Old 12-22-2012, 04:55 PM   #14
Ruthlessone3k
My Ride: 323i
Thanks, that's one less thing to worry about.
