Couple questions. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-12-2012, 03:13 PM   #1
Patton323I
My Ride: R1100GS E46 E53
Couple questions.
Is it possible to switch the light control switch modual from the manual lights to the automatic head light contol unit and hav it work properly? And to follow up with that, I also want to switch the mirror from the standard 323 mirror to the M3 mirror with the rain sensor and auto dim. Will those functions work as well? I noticed that there was a spare un used wire plug up in the sun roof area. I would apreciate any input!
Patton323I is offline   Reply With Quote
Old 12-12-2012, 03:19 PM   #2
yetieater
My Ride: '03 330i
I believe this is a coding question..
bulletproof one piece at a time
full listing of BMW Performance parts for the E46
yetieater is offline   Reply With Quote
Old 12-12-2012, 03:20 PM   #3
Ruthlessone3k
My Ride: 323i
It might work, but not with those wheels. You should probably just send those to me
But really, it would probably depend on where the sensors are. if the mirror has the sensor built in then it should be fine as long as it has power while driving. as for the headlights, I'm not sure where the sensor is but I'm guessing it would most likely require support from the ECU for that function to work.
Ruthlessone3k is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-12-2012, 03:34 PM   #4
Patton323I
Damn... I thought the wheels would be an issue. Better switch back to stock
I was always under the impression that the control unit for both the rain sensor and the auto headlights was in the fancy Mirror itself. Ill have to dig a little on that one. Ill probably use the Mirror out of the E53 as well, I'm not a huge fan of the oval.
lights, mirror, swap
