Old 12-12-2012, 03:43 PM   #21
My Ride: Lexus
Originally Posted by gaby1088 View Post
The nature of the situation does not suggest it is a mechanical issue. From one second to the next it reads it's overheating. Then he turns off the car and it reads cold again. What sensors could it be?
if you replace the entire cooling system as you say, then it would not be a sensor.
did you replace the fan switch? (sensor)
Old 12-12-2012, 03:46 PM   #22
///MPR77
My Ride: 02 ///M3 Tri-Ped
Intermittent overheating can also be, and will be caused by air bubbles.
Old 12-12-2012, 04:01 PM   #23
gaby1088
My Ride: 993
No sensors, just radiator, hoses, reservoir tank, water pump.
Just strange that it reads as if it is overheating. Unless the car can actually overheat in 1 second and cool off as soon as he turns it off lol
Pictures by boligrafo123 & ///OSS
gaby1088 is offline   Reply With Quote
Old 12-12-2012, 04:33 PM   #24
My Ride: Lexus
That isn't the whole system. Not even close.
Back to post #2.
Old 12-12-2012, 04:48 PM   #25
Chris C
My Ride: 2001 325Ci
Sounds like air in the system. The process for properly bleeding the system has been discussed so I won't repeat it. The temperature sensor that goes into the lower radiator hose could also be flakey and need replacement. Good luck with resolving this issue.
Chris C is offline   Reply With Quote
Old 12-12-2012, 04:55 PM   #26
majestic69
My Ride: 330ci sport
ty for the step by step i did that last night and i just checked it was way low plunger was all the way down ???? what the **** could it be air bubble maybe i need to re bleed it again i just added 50 50 mix and ran it for half hour it never went past the normal runing temp
majestic69 is offline   Reply With Quote
Old 12-12-2012, 05:39 PM   #27
///MPR77
No problem
Good, keep an eye on it....just don't go doing any runs up Teton pass just yet.
Sent from my SAMSUNG-SGH-I727 using Bimmer App
Old 12-12-2012, 05:49 PM   #28
majestic69
k ty so much MPR77
Old 12-12-2012, 06:17 PM   #29
scarede46er
My Ride: 2001 BMW 325i ZSP
Where in Wyoming are you? Wyoming is brutal for german cars. Ask me how I know.
Old 12-12-2012, 06:24 PM   #30
majestic69
ur prob in wy lol how do u know
Old 12-12-2012, 06:26 PM   #31
scarede46er
I was in Wyoming last year. Absolutely hated it. I mean I love the people and culture. But the weather is brutal. I hit the oil pan of V8 Passat twice-- second time catastrophically. Water on my shoes entered the accelerator pedal and froze in there, completely destroying the TPS. I was in Laramie, BTW.
Old 12-12-2012, 06:28 PM   #32
///MPR77
I lived in Alma, CO (South Park)
10,5xx feet elevation. Highest Municipality in the US
I Used to have to park facing South in the winter to keep snowdrifts from piling in through the kidneys.
Blankets over the engine on really cold nights. Etc...
Average Annual temperature 43F
My X3 6MT m54b30 was fantastic in the brutal winter.
It was brand new, but if your car is well maintained it will hold up fine.
My Bavarian Grandmother told me it does get kinda cold in the mother land as well, so these cars are built for cold.
Old 12-12-2012, 06:29 PM   #33
scarede46er
Don't envy you. I am glad I am in the south now. Same kinda people. WAY better roads and weather.
Old 12-12-2012, 06:37 PM   #34
majestic69
ya here u got to be real careful how u drive. The roads are total **** and car is super low. Below zero out here lately
Old 12-12-2012, 06:38 PM   #35
scarede46er
I usually love driving. I hated it there, with the narrow interstate and wind that blows you across lanes. Comically the speed limit was 80. Ya right.
Old 12-12-2012, 06:39 PM   #36
majestic69
haha thats no **** by time u cut through the wind ur going way slower then 80
Old 12-12-2012, 08:04 PM   #37
///MPR77
I lived in the south too,Kennesaw, Georgia...went to high school there nearly 20 yrs ago.
In Los Angeles now, because work.
Yep Hence those huge snowdrift barriers on the I-80
Old 12-12-2012, 08:23 PM   #38
majestic69
ya i bet dam
Old 12-13-2012, 08:41 AM   #39
Viktimize
My Ride: 2002 325i,2003 330ci
So did bleeding fix this?? My car is doing the exact same thing. Sure doesn't seem like an actual temperature issue. The gauge spikes high right from the blue mark, then as soon as you cycle the key it drops right back down to where it was before the spike.
I have already checked my coolant level and it is perfect. And this problem only started happening since it got cold here(below -20C)
Viktimize is offline   Reply With Quote
Old 12-13-2012, 08:53 AM   #40
WDE46
My Ride: '13 128i, '04 330Ci
I said from the beginning to just replace the temperature sensor/fan switch. It's like $15. Just try it.
Whenever instrumentation acts funny it's got to be either the battery or a sensor...rarely is it the actual dial gauge.
