Sponsored by BAVSOUND
Old 12-13-2012, 04:42 AM   #1
dan19
My Ride: bmw e46
Why are my speakers on one side of my bmw e46 only working??
dan19 is offline   Reply With Quote
Old 12-13-2012, 05:10 AM   #2
PH03NIX46
My Ride: 2003 M3
Blast that and blow them back into operating conditions.
Eibach | Sportline | OEM Euro Headers | TTFS
PH03NIX46 is offline   Reply With Quote
Old 12-13-2012, 06:42 AM   #3
scarede46er
My Ride: 2001 BMW 325i ZSP
Amp. Done.
Old 12-13-2012, 07:51 AM   #4
ddombrowski
My Ride: 01 330ci 5spd
Send a message via AIM to ddombrowski
Yeah the trunk amp is going out. Mine does the same thing.
ddombrowski is offline   Reply With Quote
Old 12-13-2012, 09:16 AM   #5
330iPilot
My Ride: Titanium Silver 330i
Could also be intermittent connections. It may be worth disconnecting plugs and spraying w/contact cleaner to make sure.
330iPilot is offline   Reply With Quote
Old 12-13-2012, 09:27 AM   #6
Brinkley
My Ride: 99 328i, 07 z4 3.0
Indeed. Can't hurt to look into connections before buying new amp.
Brinkley is offline   Reply With Quote
Old 12-13-2012, 10:56 AM   #7
ryannel2003
My Ride: '04 Cadillac Deville
I would assume you checked the balance control on your headunit first? If so, I'd also be looking into amp.
ryannel2003 is offline   Reply With Quote
Old 12-13-2012, 11:17 AM   #8
scarede46er
Too bad you are in Aussie land. Else I have/had a spare amp.
Old 12-13-2012, 08:32 PM   #9
DBrown
My Ride: BMW 325 Ci
If you have the hk setup like mine you have protection circuits, so if there is a short, ie blown speaker or loses wire or metal touching the positive lead it will kick into protection mode and disable some speakers, happened to me when i installed after market speakers. They worked fine and a few weeks later the leads at the back of the speakers were apparently touching the door metal, vibration made them wear through the paint a little and caused a short and before i knew it, only had half my speakers working. Check connections and wires for shorts, check for really blown speakers, cause if they are just a little blown doubt it would cause a serious enough short to kick in to protection mode. If no shorts then looks like its your amp. Maybe deck, but i don't know too much on these bmw decks so i wouldn't quote me on that.
2001 325 Ci
DBrown is offline   Reply With Quote
Old 12-13-2012, 09:50 PM   #10
dan19
My Ride: bmw e46
ah k thanks everyone i installed a sub and amp like a year ago and brought it back to place where i had it installed and they tested the speakers with some tool and said there working and then he said it could be some box in boot that could be stuffed but how can i check ?
