E46 Xi Forum
Old 12-13-2012, 05:58 PM   #1
Mflara20
My Ride: 04 330i
Help with tranny fluid change
Hey guys I want to change my 02 330xi auto (steptronic) tranny fluid. I went and look under my car and I have a green sticker with part number 83220024359. I bought redline D4 auto trams fluid. Did a bough the right one?
Mflara20 is offline   Reply With Quote
Old 12-13-2012, 08:22 PM   #2
mmaldin
My Ride: '04 325xit '94 325i
You should use dextron VI. You may call your local dealer or insert that part number into a dealer parts site and you will told the same.
Sent from my Nexus 7 using Bimmer App
mmaldin is offline   Reply With Quote
Old 12-13-2012, 08:46 PM   #3
White_Knuckles
My Ride: 2003 325xi
D4 was a preferred choice for many XI owners with the GM trans. I've read several posts where it has been stated - D4 is VERY close to the original factory (Texaco) spec. It has been in more recent years that BMW recommended Dex VI as a replacement. D4 is known to blend well with the remaining fluid and be chemically compatible. User tested - user approved.
You're fine and D4 is going in my ride (74 K mi.) next spring.
Old 12-13-2012, 11:06 PM   #4
Mflara20
My Ride: 04 330i
Man that's good to hear. Thanks
Old 12-18-2012, 06:23 PM   #5
7xWDC-MSC
My Ride: 2005 325xi
Yup you're golden, many folks have used it with great results.
I used Liqui Moly top tec 1200 with good results so far (3k miles) It's spec'd on their tech sheet as a replacement for the Texaco 8072-b fluid we have.
ZF lifeguard fluid is also spec'd a replacement fluid, but at around $17 a quart, not worth it.
7xWDC-MSC is offline   Reply With Quote
Old 12-18-2012, 10:56 PM   #6
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
I'm running d4
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 12-19-2012, 04:55 PM   #7
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
The Redline D4 should work just fine as long as there are no other internal issues. I would not recommend pressure changing the fluid.
tomoyer is offline   Reply With Quote
