Old 12-17-2012, 10:54 AM   #21
bigugly
My Ride: things that go fast.
:SMH: again. a stuck open thermostat STILL has restrictive qualities to slow the water down enough to make it work. yes, it is open, yes it wont go to correct temp, but there is still restriction in the system to make it work.
a GUTTED thermostat does *NOT*.
once again, you are note accounting for a variable: i have seen this a bunch of times. i have touched thousands of BMW's. care to wager who is right?
fabrication is meditation
the only thing I can't fix is broken hearts.
https://www.facebook.com/BMWdoctor
I want to be your BMW products' authorized installation center in Houston.
bigugly is offline   Reply With Quote
Old 12-17-2012, 11:29 AM   #22
repoman89
My Ride: 2003 330i Sedan
It's possible that with no restriction, the system can't build up enough water pressure to work as designed. This could potentially lower the liquid's boiling point enough for it to vaporize and no longer cool as it was designed to.
Either way, your logic in your previous post is wrong and your cause and effect wrong as well. Increased flow rate, all other conditions equal INCLUDING water pressure, fan speed, etc, will always result in higher cooling capacity, and there is absolutely no such thing as a liquid flowing "too fast to cool."
repoman89 is offline   Reply With Quote
Old 12-17-2012, 11:34 AM   #23
My Ride: Lexus
This is what happens when the cooling system is nitpicked using substandard parts. Why wasn't the entire system replaced at one time?
Old 12-17-2012, 12:48 PM   #24
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by repoman89 View Post
No. The water will absorb heat no matter how fast it's flowing in a system like this. There's a reason cars with stuck open thermostats often never reach operating temperature - flow rate is too high and therefore the fluid transfers too much heat. As flow increases more and more, the system will remove as much energy from the system as the radiator is capable of dissipating.
If when working on a car there was ever a time when the temp was stable with a certain amount of fluid flow and then increased/overheated when you increased the flow, I promise you there was another variable you don't account for.
I also guarantee that BMW used this very same "theory" to design the cooling system, and used many other "theories" to make the engine work as well as it does. Outright dismissing the physics that makes design of these cars possible is silly.
+1. Thanks for backing me up. It's just some basic heat transfer principles. BMW uses the same things I have studied and experimented with to design their systems plus their own domain knowledge. So bigugly you can take it from the guy who has a degree in things of this nature.
There is no situation our cars could get into in which an open thermostat would cause the car to run hotter. Like I said before, it doesn't work like that.
I guess a "gutted" thermostat could cause this depending on the design of the water paths. It MAY need some obstruction to guide water one way or another. I highly doubt this. What you said about water flowing too fast is dead wrong though. I'm only yielding on the effects a gutted thermostat may have as I do not know the exact route of water around the engine and other places. The thermostat doesn't need to "slow the water down".
Old 12-17-2012, 12:53 PM   #25
bigugly
i dont know what it is that makes me smirk about the situation. and yes, i have run across "you types" before working on their cars..... i love engineers and "educated" people tell me how to fix their cars lol
street smarts > book smarts.
Old 12-17-2012, 01:11 PM   #26
WDE46
I'm just telling you that your cause and effect analysis is wrong. It is not happening because the water is moving "too fast". Like I said, it doesn't work that way god damn it. Also, we engineers design the stuff that you make a living off of. We know the actual principles under which it functions. Apparently you do not. You may know how to troubleshoot down to a part but don't ever think you'll one up me on something like thermodynamics or heat transfer. Those are fundamental subjects.
Old 12-17-2012, 02:17 PM   #27
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Going back just a bit to the 'what's this white powder' all over my engine...that is a leak.
You said that you had steam coming from your bleeder before, and when you wrote that, I thought the bleeder was closed...if so, there's a big issue for you.
If steam is getting out, air is getting in.
You also seemed to indicate that you bled for 15-20 mins. with the car on...not official bmw bleeding instructions. See Mango's sticky or search me for "alternative bleeding method" (where you rev car quickly when it's cold).
The radiator getting blocked after 2 years seems unlikely. But, as your lower hose is cool, I guess the overheating is getting picked up by some sensor other than on the lower hose. Lower hose should be cooler, of course in proper use...but also, you know, if your wp isn't working right, that would affect circulation considerably too. I believe you could have an issue where the impeller is loose on the shaft, even though it feels firm. I know that happens on PS pumps.
I've read that if you see water squirting into the top of ET (start car when cold and see if you see a stream)--then wp is okay. Otherwise, there you go.
I'd start with bleeding again the proper way...and look for something 'misting' coolant (bleeder, temp sensor, ET cap)...shouldn't mist. You're letting air into system, which could cause a bubble to block passages and/or cause wp to cavitate.
I won't argue anyone about thermodynamics. I actually studied that in college many years ago, but it seems to me that the radiator is going to remove heat at about the same rate, based on the speed you're traveling and air temp. If the coolant is moving faster, it just seems like it'd maintain an equilibrium at some temperature, other than overheating. I hope so...I've passed along the 'trick' I'd read of removing the therm from housing, and won't again if the mechanic wins the argument over the engineer.
Anyway, WDE, although I believe you, I also trust the experience mechanics have. As you say, 'you' engineers design the things mechanics make a living on. You might know the actual principles involved, but evidently, some parts you engineers are making so the mechanics make way too much money on, because they fall apart all the time! LOL
Facebook.com/DMAXstandup
Mangofy your E46!
Old 12-17-2012, 05:26 PM   #28
bigugly
thats why i love working on cars. i fix engineer and manufacturing mistakes daily. i also enjoy being the "uneducated dirty mechanic" who doesnt know jack ****, since im not "educated" ...... and normally make more than the person who brought it to me lol
Old 12-17-2012, 06:12 PM   #29
WDE46
This isn't engineers vs mechanics. That is a stupid battle. We have completely different jobs. Stop making such an effort to be offended. Nobody said you were "uneducated" or "dirty". When we have a problem at this plant, guess who I go talk to first? I talk to the guy on the assembly line. I have no problem taking opinions/analysis from someone less "educated" than me. Just an example.
Anyway, my only problem was with your analysis of the cause of overheating as a result of thermostat gutting. The cause of the overheat could be the gutting of the thermostat, but the mechanism (the real cause) is not as you described. That would be the fact that a high flow rate can cause a higher temperature. That is false. That's all I was commenting on. That falls into my realm of knowledge. I didn't bust my ass for several years to argue fundamentals of physics on the internet.
What falls in your realm of knowledge is that sometimes gutting a thermostat can cause an overheat. For you the theory behind it does not matter. The only thing that counts is that you know gutting them can cause the car to run hot for some reason. You don't HAVE to go farther than that. That is all.
Old 12-17-2012, 11:18 PM   #30
TobyB
My Ride: 2004xit, 2001ci
umm, have you looked at the water pump? If it had a plastic impeller and that disintegrated, that'd explain your symptoms.
And your cap might be stuck- that happened on the E36, and it blew parts apart pretty regularly
until I changed it.
On the 2002, E21, E30 and 36 (and probably E46), if you pull the thermostat, it defeats most of the cooling system, as the thermostat is a
'dual' valve that redirects water from flowing just through the block to (partially, usually) flowing through the block, then
the radiator. So if you pull the t- stat entirely, it might cool ok at idle, but at speed, it isn't flowing enough water through the
rad to really cool the engine.
Another really quick test. when stone- cold, pop the reservoir cap to make sure there's no pressure in the hoses, then replace the cap.
start the car, stab the throttle hard 2 or 3 times to 4k or so, then switch off. Then see if there's pressure in the hoses.
If there is, that's a SURE sign of a leak from the cylinders to the cooling jacket.
If not, it MIGHT only be leaking hot...
And from past experience with older cars with 'non- bypass' cooling systems , remoing the t- stat entirely made the things run
cold, until the radiator was overloaded, and then they overheated just like they did with a thermostat. The water didn't go by 'too fast' to cool...
t
Last edited by TobyB; 12-17-2012 at 11:22 PM. Reason: don't forget the reservoir cap- they fail
TobyB is offline   Reply With Quote
Old 12-17-2012, 11:47 PM   #31
STORMER
My Ride: AA SC 98 M3
Seriously sounds like just a blockage... or a waterpump is shot... does not sound like a compromised head or gasket... it would have turned up in the hydrocarbon test as the cooling system cycles though the expansion tank. Seriously just sounds like coolant is not being cycled through the system for some reason. I feel your pain
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 12-18-2012, 12:10 AM   #32
bigugly
t
Holy crap another person knows what I'm sayin from personal experience
Old 12-18-2012, 02:30 AM   #33
mack89
My Ride: '02 TIAG 330i 5spd
Ahhh, thank all of you guys for helping me out. But seeing you guys arguing over the theory vs experience, feels like I'm the one caused this argument! So please, let's take it easy and do our favorite thing: solving the problem
Anyway, I'm really relieved because it sure doesn't seem to be a damaged head/HG. Numerous test & evidence, and your opinions convinced me. Now I need to find what the problem is.
So, today's diagnosis.
After replacing the radiator and flushing out the system real hard by using garden hose while let the engine running, car overheated at idling again.
Since I used garden hose, system was full of water. No presence of antifreeze coolant. It seemed safe to run the engine with 100% water since the pressurized system raises the boiling point, and according to OBD2 reader, coolant temp did not go over 210.
Temperature needle was guarding its post in the middle just fine for at least 7-9 minutes, and lots of air was coming out of funnel as if the water was boiling.
(*I used this funnel.)
But, at certain point, air stopped coming out. Then the needle went AWOL-overheated. Needle didn't hit the redzone, but it certainly fell toward right, just before the 3/4 marker. I'm not sure why, but it did not continue to lean toward redzone til I turn off the engine. I saw the tilted needle when I got back to my car, but didn't turn off the engine for 10 seconds because it didn't move at all. So...2 hours of flushing and bleeding wasn't really helpful, only narrowed down the source of problem a little. Sure did prove that my theory(or belief) based on 'gutted thermostat test' was false, as the car exhibited almost identical symptom.
But here's something interesting.
1) Lower hose was little warm til it overheated. After the engine overheated, I touched the lower hose and it was really hot and hard, just like upper and my thing. Radiator was cold, though. No wonder.
I thought the one of the most obvious symptom of stuck-closed thermostat was 'overheat while driving, hot-hard upper hose, cold-soft lower hose'. Maybe me being confused...
*I'm not sure I've mentioned this before, the water pump is in good condition: the impeller is composite and shaft was holding the impeller firmly. No spin or whatsoever. So, if the water pump was shot, temperature needle wouldn't even hold the ground for 3 minutes, right? Also the engine did not overheat during the test drive performed every time after I made changes.
2) After turning off the engine, thermostat housing made some weird noise.
The noise was quite similar to the noise of engaging solenoid or valve, short burst of mid-high pitch'd noise. Or water getting boiled inside.
Thermostat made this noise several times periodically and rapidly, stopped after few seconds.
And I saw this metal probe connected to a thermostat connector before, so I gotta ask this. What in the world is that? Is that some kind of heating rod which receives current and forces the thermostat to open? If it really is, then I might be looking at the whole new problem--bad ECU...
Oh GOOOOOOOOOOOOOOOOOOOOOOOOD this seems to be going nowhere.
I'll be taking out the thermostat and put it in actual boiling water, see if it opens or not.
Also I should figure out what the metal probe is, so I can make another theory.
And hey, thank you guys so much for taking time and effort to help me out.
mack89 is offline   Reply With Quote
Old 12-18-2012, 02:49 AM   #34
mack89
Back to the suspicion about water valve, suggested by lcoleman.
jinbtown in BF had almost identical problem, his solution had something to do with water valve/heater valve.
http://forums.bimmerforums.com/forum....php?t=1844058
Do remember that there was no water in heater return hose. Could this be related?
Old 12-18-2012, 04:47 AM   #35
Mcbridges11
My Ride: 03 325i, 03 540i
I skimmed your problem- sorry if its repetitive- If you can bypass your heater control valve that would tell you if it were the hcv- just connect the two hoses that go into the valve but make sure you know the inflow and outflow hoses for reconnection- the valve is on your drive side strut tower below your intake/maf. - the return hose that goes to your expansion tank can be left in place- I've heard you can also unplug that sensor and if you get heat it's the valve if not spend your time elsewhere- i took mine out and took it apart- turns out after time the seals fail/particles get into your system and the fluid fries the solenoid-** this wouldn't explain your overheating issue as this just allows hot fluid to the heater core- Have your tried a reverse flush on your whole system? Draining the block and all? Before that I would make sure your water pump is working properly- easy way to check is to take the expansion cap off and start your car (do this cold so you don't end up a burn victim) you should see a stream of fluid coming out the side- a failed water pump would cause both symptoms of no heat/ overheating-
Mcbridges11 is offline   Reply With Quote
Old 12-18-2012, 12:19 PM   #36
bigugly
the pee pee squirter in the expansion tank will tell you if the water pump is functioning.
will you put an effin thermostat in the effing engine please?
you have massive air pockets and a bad thermostat (still) it seems..... a coolant evacuation system would solve 1/2 of this.
Old 12-18-2012, 12:29 PM   #37
WDE46
lmao agreed
Old 12-18-2012, 01:01 PM   #38
mack89
Lol! Guess I didn't state the fact that I've already gotten a new replacement from oreilly and installed it.
So, new(might be defective, will check in few hours. DIVE, DIVE, DIVE!) one is in the engine, still exhibiting the same symptom.
I suspected a defective part, so I already bought a Behr thermostat. It will be installed as soon as I'm done with testing oreilly replacement thermostat.
Oh and mcbridges11, I'm glad you pointed that out. Stream of water does come out from the side of expansion tank when the engine's running. So I believe I can safely assume that water pump is working well.
Old 12-18-2012, 01:06 PM   #39
My Ride: Lexus
As I said, replace the entire system and stop shopping at O'Reilly
Old 12-18-2012, 03:08 PM   #40
mack89
I wish I had choice
Had to attend school daily, rental was way too expensive, no way I could had gotten 50 miles of ride back and forth til parts arrive, etc.
Circumstances weren't my friend lol. Now I'm replacing everything with OE parts. Hope it solves the problem..
By the way, does anyone know what the metal rod is? I did some googling, some say it's a heating rod as I suspected, but I need second opinion..
