Old 12-27-2012, 11:11 AM   #81
My Ride: Lexus
Originally Posted by Juliopinto03 View Post
Sorry to bump Mango but as my friend exited my E46 today he said my exhaust fumes smelled like anti freeze
I would not come to any conclusion based on an opinion from a friend traveling on a public road behind you. See for yourself.
Old 12-27-2012, 11:58 AM   #82
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
...although...OP could confirm it by having someone else start it after it's cooled down a bit...like in the a.m.
If you have coolant leaking into cylinders, like I did in my e36, you'll notice it worse when starting in a.m. It'll sputter until it burns off...then the amount leaking is so slight, it's not noticeable...until it gets worse and worse. There are many different fractures possible that can lead to this...just the gasket or in the head (as happened to me).
Facebook.com/DMAXstandup
Mangofy your E46!
Old 12-27-2012, 12:49 PM   #83
mack89
My Ride: '02 TIAG 330i 5spd
@dmax
OMG Doug don't say that
My E46 sputters at cold start, but only when cold. When the weather was pretty warm few weeks ago, it started right up perfectly(hit 1400rpm at start up). And OBD is throwing P0101, MAF malfunction, so I guess this POS MAF has gone bad already(35k miles).
Interrogative, did your E36 have exactly same symptom as mine? Hot upper/cold lower&radiator, overheating under load(drive), and coolant overflow?
And what kind of tests did you perform in order to determine head failure? Compression test, combustion leak test(blue fluid), etc?
mack89 is offline   Reply With Quote
Old 12-27-2012, 01:03 PM   #84
dmax
dmax's Avatar
I just had a cold start sputtering...loss of coolant (maybe 1-3 ozs (at the end)). This happened after a substantial overheat and radiator neck blowing apart at the end...before I knew anything about cars!
In the end, I don't know what tests the shop did, but they showed me the cracked head.
I wasn't overheating, but I wasn't losing a lot of coolant either and kept it topped up. I went for a few months until I knew it was something serious. Then, 6 months after the work was done, some idiot totaled my car! sigh
Mangofy your E46!
Old 12-27-2012, 01:08 PM   #85
My Ride: Lexus
I didn't know you knew anything about cars.
Old 12-27-2012, 01:16 PM   #86
dmax
dmax's Avatar
Ha! Surprisingly, it's both very little and more than most!
Mangofy your E46!
Old 12-29-2012, 12:30 PM   #87
mack89
Well, I have come to a conclusion. I've checked dipstick dozen times before, it did not have chocolate milkshake. It does now, for some reason.
Definitely head/HG is blown, but I don't know what to do next.
a) Sold as-is and get another one? A friend of mine is selling his 02 330i w/ Mtech1 for $4500. But the problem is, I don't know how much I could get with my e46. It has a lot of new engine/cooling system parts, new suspension parts, etc etc.
b) Swap the engine? I found a 328 engine with transmission for $1800(or $1k for engine, $500 for 5spd stick swap), but plus labor($700, found an indy mechanic)..I'm not sure it's worthy at all.
Old 12-30-2012, 12:22 AM   #88
STORMER
My Ride: AA SC 98 M3
Glad you have reached a final conclusion
You now have a tough decision to make
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 12-30-2012, 12:31 AM   #89
scarede46er
My Ride: 2001 BMW 325i ZSP
Have you considered parting out the car instead? You are more likely to get your money for the new parts that way. Then use the proceeds to get a new car. My 2 c.
Old 09-10-2013, 08:59 AM   #90
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
So sorry to hear this was the conclusion after all you tried. I read all thru this thread for a few hours anxiously wondering what the cause would be, since I also have an overheating problem. Mine has never gone into the red yet.
What did you end up doing with the car?
