Old 12-15-2012, 11:29 AM   #1
chillinhardinanE46
My Ride: 2003 325i
M56 sulev info
So Ive been trying to solve a rough idle problem (misfires I think).
While going through another members steps for resolving misfires and I realized something pretty interesting. The M56 engines do not seem to have a CCV. Please correct me if i am wrong. As you can see in the real OEM diagram, the dipstick tube goes straight into the oil pan.
http://realoem.com/bmw/showparts.do?...03&hg=11&fg=10
I guess thats one less thing for me to check while trying to find the reason for my misfires
Also the air intake boots seem to have a much better design which would limit the usual cracks at the bottom. These have more meat on them and less of the folds where the cracks usually occur (I think).
chillinhardinanE46 is offline   Reply With Quote
Old 12-15-2012, 01:01 PM   #2
SpoonerDee
My Ride: 2005 E46
http://en.wikipedia.org/wiki/BMW_M56
Crankcase ventilation system:
The crankcase ventilation valve is incorporated in the aluminum cylinder head cover.
SpoonerDee is offline   Reply With Quote
Old 01-07-2013, 06:44 PM   #3
chillinhardinanE46
My Ride: 2003 325i
Thanks for that insight SpoonerDee.
I guess this is another headache for us M56 owners-_-
Does anyone know if this CCV can be repaired/replaced? Im assuming its aluminum as well. cant it be removed and cleaned or fixed?
ive noticed bolts in the underside of the valve cover.
Old 01-07-2013, 07:12 PM   #4
Blizare
My Ride: 2001 330xi
You probably replace the whole Valve Cover.
2001 330xi
2003 530i
Blizare is offline   Reply With Quote
Old 01-07-2013, 07:22 PM   #5
chillinhardinanE46
My Ride: 2003 325i
crap
i really ope it turns out to be something else and not my CCV. This mechanic that came by the other day mentioned he might be able to fix it. I hope he can.
If not thats $500 minimun
Old 01-07-2013, 07:23 PM   #6
KingBee
My Ride: IR '03 M3
you probably replace half the car and spend $5000...that's SULEV for ya
AA exhaust, PSS10, TMS sways, 5mm rear spacers, more to come!
KingBee is offline   Reply With Quote
Old 01-07-2013, 07:33 PM   #7
briangl92
My Ride: VQ37VHR
Check the link in my sig. You may still be covered under warranty - if you are, you can take it to the dealer to have them deal with the issue. All the documents are in that thread. Let me know if you need any help.
briangl92 is offline   Reply With Quote
Old 01-07-2013, 07:40 PM   #8
chillinhardinanE46
My Ride: 2003 325i
Thanks for chiming in. I have gone over your thread plenty of times. Thankyou for creating it. I didnt know that the CCV could be covered under te emissions warranty !! If so thats wonderfull news! My car is still under the 150k/ 15 yrs. Now ill just have to prove to BMW that the CCV is my problem. I dont wanna let them try and end up with a bill.yu know how good they are at that
Old 01-07-2013, 07:44 PM   #9
briangl92
My Ride: VQ37VHR
CCV/valve cover is listed on page 2 of that first attachment Glad to hear that thread is helpful!
I know all about them trying to stick you with the bill. I recommend printing out that attachment and bringing it with you. They were refusing to cover mine until I showed them their own TIS document.
Old 01-07-2013, 08:23 PM   #10
tech4tech
My Ride: e46, 325i
Actually, you're in luck. First, CCV is likely going to be covered by the 15year/150k miles warranty by the dealer.
Second, even if you were to replace it yourself, CCV is a part of the valve cover on M56-- no need to spend 4-5 hrs contorting yourself to replace it or paying someone for that much labor as you would with M54. The cover itself sells online for about $470 brand new. This valve cover is made of aluminum and doesn't crack, and is actually easier to replace than the plastic valve cover on M54 due to easier access.
Third, there's only one short plastic hose involved going from the VC CCV to Intake. Pop it off and check if you see oil pooling there. To access that area, just pull up the black engine cover -- it's just friction-mounted with rubber grummets unlike on M54.
Check the picture in post #28 here. It shows where that hose connects
http://forum.e46fanatics.com/showthr...=726141&page=2
tech4tech is offline   Reply With Quote
Old 01-07-2013, 10:28 PM   #11
chillinhardinanE46
My Ride: 2003 325i
Thanks for the post and information guys.
I think I have found the problem!
briangl92: Thanks for that information I will print this out and take it with me. I recently rolled the dice with BMW...
Took the car in for code P0430 and they said CATS were good. I told my buddy jokingly that they would say its an airleak when i dropped it off. When i picked it up they stated it must be an air leak after the MAF or a faulty MAF. So I got charged lol.
Tech4tech: THANK YOU. This is exactly what I have been looking for. I dont know why i couldnt find that posting earlier. I swear i tried searching. I checked out the picture as you mentioned and guess what!! I found oil where you said to check.
Look at this picture attached. I took this before I left work.. car was sitting minimum of 4 hours.
After I saw this I didnt wanna drive my car anymore after what I read in the other post you linked.
So am I dealing with a failing CCV here guys? Im assuming yes but would like to confirm.
Also if I go back to the dealer and tell them what I found, what is the likelyhood that they will admit or say that the CCV is at fault? Is the oil in the hole a definite sign of a failing CCV or can something else lead to this?
I will be taking the picture and the TIS document with me. I will probably have to wait until wednsday.
BTW i appreciate your guys help.
Old 01-07-2013, 11:19 PM   #12
tech4tech
My Ride: e46, 325i
I was recently working on replacing the valve cover gasket on my friend's car (M56 SULEV) and saw the same pooling of oil at the CCV outlet. However I am not convinced if that means the CCV is bad.. possibly this sort of oil accumulation over a long period of time is normal. Perhaps someone more knowledgeable on this topic could chime in. And you're right, it's pretty hard to find info about the SULEV engine because there isn't that many of them around. Please keep us posted on the progress.
Old 01-07-2013, 11:43 PM   #13
chillinhardinanE46
My Ride: 2003 325i
Yea most everyone doesnt want anything to do with them.
I ended up with one because im lucky
Does your freind have a rough idle? Loss of power?
Also would somone with a new or properly working CCV with M56 engine post a pic of what this hole looks like on their car?
I dont really want to drive the car in fear of hydrolocking. But I want to clean the hole and see how much oil accumulates after a drive.
What do you think?
Old 01-07-2013, 11:47 PM   #14
tech4tech
My Ride: e46, 325i
He had other issues, so it's hard to say. Vanos seals were completely fried though.. hard as plastic. How many miles do you have on your car? Yeah, I'd say clean that up, and take it for a drive. Do you have any codes?
Old 01-07-2013, 11:57 PM   #15
chillinhardinanE46
My Ride: 2003 325i
Did he have to replace his Valve Cover?
Car has 114k or 115k I believe. I replaced VANOS at about 111k. Then for a while everything felt perfect except for a tiny almost unnoticeable vibration. I figured it was normal since it is a 10 yr old car. This was about June/July. The past 2 months ive noticed the unnoticeable vibration become a big annoyance as the car vibrates very noticably at stops. Which I think yu guys have helped me diagnose to be my CCV. I read the other post that was similar to mine. The OP had similar oil puddles
Old 01-08-2013, 12:06 AM   #16
tech4tech
My Ride: e46, 325i
We just changed the VC gasket so far. The spark plugs should be getting fouled up if the CCV is bad, no? Did you check/replace the plugs recently? What about the vacuum leaks (intake boots) and cleaning ICV and MAF ?
Old 01-08-2013, 12:20 AM   #17
chillinhardinanE46
My Ride: 2003 325i
Heres pics of my plugs i checked last week they. I only checked the 1st 3 and they all looked similar. I replaced em at 111k Ive checked for leaks cleaned ICV and MAF. I will be having mechanic smoke test my car for leaks soon.
ID:	485114   Click image for larger version
Old 01-08-2013, 01:17 AM   #18
briangl92
My Ride: VQ37VHR
I don't know if I missed it, but are you getting any codes? With a rough idle you should be getting codes. If not, then I'd start considering stuff like engine mounts.
Old 01-08-2013, 01:27 AM   #19
chillinhardinanE46
My Ride: 2003 325i
Yea I am getting code P0430. Ive gotten a misfire once, but that was after i switch two coils around. I have another thread with more info on codes and how the car acts here http://forum.e46fanatics.com/showthr...897616&page=22 post #430 .... just noticed that little coincidence. lol
I did think about the engine mounts but the car is pretty smooth while accelerating and driving. Not only that but I also have a cold start shuddering issue, and recently my mechanic mentioned that a suction noise that occurs when turnining off isnt normal (I thot it was) so its starting to make a bit more sens that its the CCV. I noticed that oil is also going into the hose that connects the vanos to the Intake Manifold. I wasnt able to take of the IM end of the tube as it was super hard and I didnt wanna break it. But im sure its in the same condition as the vanos end is.
What type of test can confirm the CCV. on an M56? vacuum test, smoke test?
Old 01-08-2013, 07:44 PM   #20
tech4tech
My Ride: e46, 325i
There's the plastic bag over the oil fill hole test, but the suction noise seems likely to be CCV related. I am not sure how the dealers test this
