Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 4.73 average. Display Modes
Old 12-17-2012, 04:55 AM   #21
zuckuss00
My Ride: F22 M235i JB4
Originally Posted by mikhit View Post
Your question about my driving habits is a really good one, because as you noted that will affect consumption. But no I haven't altered my driving at all. I do believe that the improvement in consumption that I am experiencing is a result of the MOA. However, as I alluded to before, I am working off of limited data at this time, and won't make any absolute conclusions until I have more complete data.
So far I have added the MOA at a 3000 mile interval. This interval works out to maintain a reasonable concentration of MOA with respect to the rate at which I am consuming oil, without exceeding BG's recommendation of MOA to oil ratio. Looking ahead, I will most likely just add a can during my regular oil change and then 1 more between my 7500 mile oil change interval...however this should all be adjusted for individual rate of consumption...
I never did get a compression test; deemed it would be inconclusive and thus not worth the expense...
Excellent, thank you for the information. Last question, what kind of oil have you continued to use with the BG MOA additive? I'm currently running OEM 5W-30, however, I'd like to also switch to a thicker oil to also assist in slowing the rate of consumption, possibly a 0W-40. I'll also ask my technician this question, but I'd just like to know what other people are running in their E46s.
BMW ///M235i - JB4 Stage 2 (364whp)
Originally Posted by DAm3Kid View Post
FELLAS.........DON'T GET ZUCK'D!!!!!!!
zuckuss00 is offline   Reply With Quote
Old 12-17-2012, 06:07 AM   #22
SteadyMobbin
My Ride: ImolaZHP 6spd M/T
Hello I am also a part of the mysterious oil losing club. Except this time I lost about a qt in 200 miles. Which is usually around 700-900 miles. I am thinking its the piston rings as their was an oil drip from the exhaust manifolds today after I shut the car down, and burning oil smell/and souund, and a lil smoke coming from that area. Also black soot in the exhaust pipe. Am I screwed, taking it to the mechanic tomorow to see what he thinks.
SteadyMobbin is offline   Reply With Quote
Old 12-17-2012, 07:29 AM   #23
mikhit
My Ride: 2003 325xi
Originally Posted by Stinger9 View Post
You can do a compression test yourself with a cheap gauge. Simple; I did it when I was 17 yo. Easy DIY.
True. I was prepared to do it myself, and will probably still do it sometime in the future, but at this point only out of curiosity.
I was previously talked out of it due to the fact that it may not reveal the issue.
mikhit is offline   Reply With Quote
Old 12-17-2012, 07:32 AM   #24
mikhit
My Ride: 2003 325xi
I have always used only BMW 5W-30, with a 7500 mile oil change interval.
Old 12-17-2012, 07:40 AM   #25
mikhit
My Ride: 2003 325xi
The oil drips on the exhaust manifold and burning oil smell are textbook VCG leak. Take care of the VCG and check the rest of the engine for leaks, specifically the OFHG and vanos line.
Of course theres no guarantee that leaks are your only issue. 1 qt/ 200 miles is really excessive. But for now take care of the leaks, make sure the engine is completely dry and monitor consumption.
Old 12-17-2012, 07:57 AM   #26
klax
My Ride: '04 325i
I'd have to agree with Stinger: A lot depends on how the engine was broken in during the first thousand miles or so. I closely followed the manual after purchase (new) and at 130,000 miles I currently have zero oil consumption.
mikhit,
Great information on the BG product! It's nice to see someone impart information so well.
klax is offline   Reply With Quote
Old 12-17-2012, 03:26 PM   #27
SteadyMobbin
I litterally just changed vcg...it is not leaking the vcg metal guards are completely dry. I have a slight ofhg leak but not enough to cause this much loss...i need some real advice...
Old 12-17-2012, 03:40 PM   #28
Stinger9
My Ride: '04 330Ci
If you list the VCG, the OFHG, the CVV system, the oil pan gasket, the valve stems, and the oil rings, then you've pretty much got it all covered.
Systematically explore each until you find the guilty party.
Have you removed the engine shield underneath to see if there are any traces at all?
Old 12-17-2012, 06:04 PM   #29
zuckuss00
Like someone else mentioned, a compression test wont really reveal too much. If you're interested in oil blow by, a cylinder leak down test will possible isolate the problem to a single cylinder/piston. Even then, its just information. Having the piston rings replaced would be a very costly repair. I'd rather trade the car then pay a few thousand dollars for that repair. Let's hope for our sake and for our wallets, this BG MOA product works. I can't wait to give it a try and track it.
Don't forget to let us know what happens!
Old 12-17-2012, 06:56 PM   #30
SteadyMobbin
I went under the car today and saw the oil pan on the drivers side looked pretty oil, and the control arm seemed to be coated with some soot. Anyway to tell if its ccv? I dont want to go replacing things that dont need replacing. Thanks for the info. By oil rings do you mean the piston rings?
Old 12-17-2012, 06:57 PM   #31
SteadyMobbin
Will do! Where do you get this bg moa product? And how does it help with the piston rings?
Old 12-17-2012, 07:27 PM   #32
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
For what it's worth as a point of reference, my 02 325Ci runs OEM oil/filter changed around every 7500 miles. In that time period, I might burn through only half a quart of oil or less. The car has 108k miles.
I have replaced my oil filter housing gasket, which was leaking and causing oil dripping down the drivers side of the motor onto the oil pan. Also I replaced the Oil separator and all components, as the oil return line was seeping and brittle. But even when those were leaking, I never lost more then half a quart.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 12-17-2012, 08:58 PM   #33
Stinger9
My Ride: '04 330Ci
To answer your question, go back and read the information in my post #11 in this thread. Worth reading.
You need to clean off the leak under your car and then examine it frequently to track down exactly what is leaking.
Check out youtube for the e46 CVV test. But there is no substitute for eyes on the hoses to see if there are any cracks or leaks there.
Old 12-17-2012, 11:10 PM   #34
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
I have been using BG products for the last 10yrs. It was first recommended to me by BMW of Columbus, GA.
U can find BG products online but they are very expensive. However, if u search on eBay u can score a great deal. I paid $250 for 24 cans of BG 44K which is a steal. 44K cost around $15-20 and MOA cost around $5-10
sent from my HTC EVO+ using Bimmer App
Old 12-17-2012, 11:12 PM   #35
flashmeow
Banned User
Here is 44k
Old 12-17-2012, 11:38 PM   #36
zuckuss00
^ That's awesome!
I'm just going to order some off ebay as well.
The dealer in my area wants $20 per can. On Ebay its about $10.
Old 12-18-2012, 12:04 AM   #37
hizhinezz
My Ride: 01 330i
Just ordered 4 cans off eBay delivered for $35!
Thanks much to OP and others for info, been watching oil consumption for a while and very little info on improving this issue vs just living with it!
hizhinezz is offline   Reply With Quote
Old 12-18-2012, 12:59 AM   #38
zuckuss00
I really hope it makes a noticeable difference in the consumption rate. Fixing an internal oil consumption problem, like I mentioned before, is $$$. If this BG MOA product helps improve my consumption from one quart per ~700 miles to about ~1400-2000 miles, I'd be more than happy. That's almost normal spec for a M54.
I'm going to try this product, along with switching from OEM 5W-30 to a heavier 10W-40 and continue to record the progress.
Old 12-18-2012, 03:00 AM   #39
asma123
My Ride: E70x5 m3conv m3coupe
I was having the same problem. I was burning roughly 1L/800KM - TERRIBLE...
Anyway, I started experimenting with oils. 0w10 european formulae. It didn't improve until I changed to the CASTROL 10W40 edge with spt. (http://images.oreillyauto.com/parts/...-10w40_300.jpg)
The improvement took a little while and was slowly but it's still improving.
Initially it started out as
1L/1000KM. Topped off and it improved 1L/1200km. Topped off again 1L/1500km. NEXT I went for a long drive ~ roughly 400km drive. This time the oil lasted me about 1L/2500km. I thought great it's improving quite a bit but then it was highway drive. came back to city and light came on. I topped it off again it lasted roughly 1L/1500km. It kinda made sense that less was burnt in the highway and more in the city.
I just recently did an oil change. So far it's been 1500km. Fingers crossed. So far so good. Engine felt great today when I drove her so we'll see how long she lasts till she's thirsty again.
asma123 is offline   Reply With Quote
Old 12-18-2012, 04:52 AM   #40
RayPooley
My Ride: 320i SE Coupe
What kind of speeds were you doing on the highway? Is there any relationship between speed and consumption in your experience?
