Rating:
Display Modes |
#41 |
What exactly is this bg moa stuff? And can some one explain to me how it helps with oil loss...? Does it thicken the oil.
#42 | |
The idea is that it will help clean and break up sludge or sticky components within the engine. People use MOA for a variety of reasons, including to help quiet noisy lifters (which may be sticking), as well as overall good engine health. In the case of oil consumption, it is possible that MOA will help IF you're losing oil past the rings because they are sticking and not floating freely. Stinger's post #11 was a great overview of the purpose of each of the rings, and you can understand why they must slide freely. But if your oil consumption is the result of some other internal issue, you probably will not experience much, if any, improvement. So, I say again, this is certainly no cure all. I have personally experienced decent consumption improvement from my use of MOA over the last few months, and intend to continue to track it closely for more complete data. However, there is no guarantee that everybody's experience will be the same. MOA from my dealership costs me about $12 a can (and evidently you can find it even cheaper online or buying in bulk), so its definitely worth a try IMO. Good luck |
#43 |
Banned User
Here is the direct quote for MOA
BG MOA® prevents oxidation and thickening of engine oil under even the most severe stop-and-go, high temperature driving conditions. It fortifies all qualities of engine oil to provide superior long-lasting engine protection and helps maintain optimum engine performance. BG MOA® keeps piston ring belts, hydraulic lifters and other engine components clean to help extend engine life and reduce costs of operation. It is compatible with both synthetic and petroleum-base oils. The Thin Film Oxidation Uptake Test (TFOUT), ASTM Test Method D4742, proves BG MOA , proves BG MOA Last edited by flashmeow; 12-18-2012 at 10:20 AM. |
#44 |
Banned User
, proves BG MOA's remarkable resistance to oxidation by more than 200% longer than six major brands of SL quality oil. At the conclusion of the API Sequence IIIF Engine Test***8218; a major brand, high-quality reference oil barely passed the 80-hour test with a viscosity increase of 255 percent. At 80 hours, another brand of oil fortified with BG MOA® had a viscosity increase of only 57 percent. At the conclusion of the triple-length, 240-hour test, it was still well within the viscosity limits with an increase of only 198 percent.
#45 |
Outlier
My car goes through more oil the harder it is driven point blank. When I drive it carefully and at lower rpms the light comes on much later. When I get my foot in it for a little while, just know that light is coming on soon. Sad and simple but true.
#46 | |
I was doing roughly 90km-140km ish it was a long trip so yeah |
#47 | |
![]() UUC Motorwerks | Vörsteiner | JLeviSW | VMR | DTM-Spec | Euro Dyne | ModBargains | EAS |
#48 | |
#49 |
You are doing everything correctly. Very unusual!
#50 |
Ok I found this, looks like the best deal on ebay without having to spend over 100.
http://item.mobileweb.ebay.com/viewi...id=95583400128 Is this the right stuff, #110? |
#51 | |
Banned User
sent from my HTC EVO+ using Bimmer App |
#52 |
I too have been using BG products for years and most techs I know swear by it. The BG guys used to do a demo at a local Ford dealership. They have a Chevy 350 up on the bed of a truck. the 350 (obviously) runs MOA in the engine. They start the engine and let it warm up and then drop the oil pan and continue to run the engine for 45 minutes. They check bearing journals with an IR gun and the temps never go much over 400 degrees... Even after 45 minutes of running with no oil in the pan.
I bought a case a few changes ago. I too have had a mysterious increase in consumption recently. I just bought Mobil 1 0W-40 to try out. I'll need to change in the next 1k miles so we'll see. BTW... BG stands for Bearing & Gear... They started as a bearing and gear company and looked for ways to improve lubrication. It looks like they found it with MOA. I need to get some 44K also... I'm out.
NWS and Advertising Removed.
#53 |
E46 is strong with this one
very interesting read guys. I'll be buying MOA and 44k as well. Just waiting for CCV system to be replaced.
#54 | |
#55 |
I'm curious to find out the results of using BG MOA. I too have the same issue. Fill us in if you see any improvement in consumption.
#56 |
Banned User
I just realized that I need to get new MOAs. My oldest can had a production date of 2006. Hmm....I hate shelf life
#57 |
#58 |
My Ride: 99 328i. ZSP, ZPP,
As far as I can tell. I only see people here with M54 engines. Huh.
My M52TUB28 Doesn't burn a single DROP of oil. I put in 7 quarts of oil and when I go to change it, It's still at the same spot on the dipstick.
![]() 1999 328i Sport Package, Premium Package, 5 speed, Alpine white. Last edited by RockLee; 12-31-2012 at 02:05 PM. |
#59 | |
Lot's of us here do the same thing with oil. Expect us to be the ones who write complaints here? |
#60 |
I wouldn't say this issue is engine specific. People with the M52TU, M54 and M56 are reporting unusual oil consumption in here. The problems that cause it can happen to any engine.
