Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum. |
| View Poll Results: should firearms be banned/regulated? | |||
| Yes |
11 | 6.59% |
| Fvck No |
99 | 59.28% |
| There should be more regulations but not taken away completely |
35 | 20.96% |
| I dont care |
4 | 2.40% |
| I agree with JonJon |
18 | 10.78% |
| Voters: 167. You may not vote on this poll | |||
Thread Tools | Search this Thread | Rate Thread |
#1081 | ||
Tinfoilhatatarian
My Ride: .
Scary that the most vocal ones against guns know the absolute LEAST about them. It's no wonder why stupid fcxking laws like this are passed. Quote:
The definition of "automatic" is a "semi-automatic" gun only of it can hold 31+ rounds, unless that gun shoots a .22
Malo periculosam libertatem quam quietum servitium
#1082 |
Yeah, kinda of like California laws. Apparently if your rifle has a thumbhole stock, that's enough reason to confiscate your rifle and throw you in jail. How a thumbhole stock makes a rifle any more dangerous is still a mystery to me.
#1083 |
Most of this anti gun crap is a mystery to me...
![]() 2002 TiAg M3 OEM 19s/Fiamm triple air horn/Valentine V1/Uniden BCD396T/Uniden XL 520 Pro/Lightwerks TFX with 55 watt kit/Mediabridge 1500/Pro Fit iPhone bracket and holder |
#1084 | |
Location: Tampa/Daytona/J-Ville, FL; New York, New York
My Ride: drei hundert dreißig
"You'll Never Walk Alone" |
#1085 |
Here's what I can't find when discussing this topic. Noone seems to be able to give an accurate definition of what an "Assault Rifle" is. There doesn't seem to be a general concensus. Just because an AR15 looks like an M16 doesn't mean it's an "Assault Rifle"; Toyota races a "Camry" in NASCAR, that doesn't mean all "Camrys" are race cars. They may look similar, but they are not the same.
#1086 |
As per CT definition:
Any selective-fire firearm capable of fully automatic, semiautomatic or burst fire at the option of the user or any of the following specified semiautomatic firearms: Algimec Agmi; Armalite AR-180; Australian Automatic Arms SAP Pistol; Auto-Ordnance Thompson type; Avtomat Kalashnikov AK-47 type; Barrett Light-Fifty model 82A1; Beretta AR-70; Bushmaster Auto Rifle and Auto Pistol; Calico models M-900, M-950 and 100-P; Chartered Industries of Singapore SR-88; Colt AR-15 and Sporter; Daewoo K-1, K-2, Max-1 and Max-2; Encom MK-IV, MP-9 and MP-45; Fabrique Nationale FN/FAL, FN/LAR, or FN/FNC; FAMAS MAS 223; Feather AT-9 and Mini-AT; Federal XC-900 and XC-450; Franchi SPAS-12 and LAW-12; Galil AR and ARM; Goncz High-Tech Carbine and High-Tech Long Pistol; Heckler & Koch HK-91, HK-93, HK-94 and SP-89; Holmes MP-83; MAC-10, MAC-11 Carbien type; Intratec TEC-9 and Scorpion; Iver Johnson Enforcer model 3000; Ruger Mini-14/5F folding stock model only; Scarab Skorpion; SIG 57 AMT and 500 Series; Spectre Auto Carbine and Auto Pistol; Springfield Armory BM59, SAR-48 and G-3; Sterling MK-6 and MK-7; Steyr AUG; Street Sweeper and Striker 12 revolving cylinder shotguns; USAS-12; USI Carbine, Mini-Carbine and Pistol; Weaver Arms Nighthawk; Wilkinson "Linda" Pistol. 2. A part or combination of parts designed or intended to convert a firearm into an assault weapon as defined in subdivision (1) or any combination of parts from which an assault weapon as defined in subdivision (1) may be rapidly assembled if those parts are in the possession or under the control of the same person. 3. Any semiautomatic firearm not listed in subdivision (1) that meets the following criteria: (A) A semiautomatic rifle that has an ability to accept a detachable magazine and has at least two of the following: i. a folding or telescopic stock; ii. a pistol grip; iii. a bayonet mount; iv. a flash suppressor or threaded barrel designed to accommodate a flash suppressor; and v. a grenade launcher. (B) A semiautomatic pistol that has an ability to accept a detachable magazine and has at least two of the following: i. an ammunition magazine that attaches to the pistol outside of the pistol grip; ii. a threaded barrel capable of accepting a barrel extender, flash suppressor, forward handgrip or silencer; iii. a shroud that is attached to, or partially or completely encircles, the barrel and permits the shooter to hold the firearm with the nontrigger hand without being burned; iv. a manufactured weight of fifty ounces or more when the pistol is unloaded; and v. a semiautomatic version of an automatic firearm. (C) A semiautomatic shotgun that has at least two of the following: i. a folding or telescoping stock; ii. a pistol grip that protrudes conspicuously beneath the action of the weapon; iii. a fixed magazine capacity in excess of five rounds; and iv. an ability to accept a detachable magazine. 4. A part or combination of parts designed or intended to convert a firearm into an assault weapon, as defined in subdivision (3), or any combination of parts from which an assault weapon, as defined in subdivision (3), may be rapidly assembled if those parts are in the possession or under the control of the same person. Source: General Statutes § 53-202a (a) (applies to §§ 53-202b -- 202k). Commentary: The term "assault weapon" does not include any firearm modified to render it permanently inoperable. General Statutes § 53-202a (b).
![]() Last edited by HiHoBrian; 12-26-2012 at 09:44 AM. |
#1087 |
Purped out
And in NC
What are the relevant laws regarding Assault Rifles in North Carolina? A: Assault rifles (the real ones) are select-fire battle rifles available only to military and law enforcement. "Select-fire" means that they can be switched between semi-automatic mode (one shot per trigger pull) and full-automatic (machine gun) or "burst" mode (multiple shots per trigger pull). They are considered to be machine guns by law and are thus illegal for private citizens to own in NC. Is that the type of rifle to which you are referring? Or do you mean the non-select-fire cosmetic look-alikes, the so-called "assault weapons?" If so, we were fortunate enough to be able to make the NC legislature understand that so-called "assault weapons" are no different from any other non-select-fire gun, except in appearance. Because of their understanding, there are no state-specific laws governing "assault weapons." There are Federal laws, of course, and there are some local ordinances in Durham and Chapel Hill. The local ordinances were invalidated by a state-wide preemption law, but Durham and Chapel Hill still keep their ordinances on the books to "make a statement." |
#1088 |
They moved the annual gun buyback in LA up to today.
Idiot reporters kept throwing around words like assault rifle when they had bins full of fudd guns |
#1089 |
#1090 |
ASA NO MO
Guess my AK is considered an assault rifle. Well, since I lost it during my last hunting trip I don't need to concern myself at this point.
#1091 | |
King Redneck
Frankly, I am not at all sure that civilian gun ownership is a good idea. (For the record, I do own several guns) The fact is that for all the stories you hear about people using guns to protect themselves the numbers are incredibly low. Most guns are not being used for self defense. So what is the answer? Don't drive through Compton at midnight. Be smart. Intelligence trumps firepower every time. |
#1092 |
Banned User
My Ride: Malfouf
#1093 |
I have a 12ft starcraft with a trolling motor. Anyone want to head out on some open water for a gun cleaning party? Bring um all!
sent from my ATARI sc1224
#1094 |
Purped out
damn, dont want another accident like the one i read about earlier. please be careful guys
#1095 | |
Sent from my SGH-I997 using Bimmer App
![]() Sapphire Black MetallicNatural BrownSilver Cube e46 330i ZHP/ZCW/6MT - Sold HellrotDove Grey e36 ///M3 - RIP Alpine WhiteTanSand High Gloss e46 330i SunRoofLess/5MT For Sale: $300 winter wheel/tire set (sport edition F7s and Dunlop graspics) For Rent: RTAB Removal/Installation and Preload Tools |
#1096 |
ASA NO MO
Really? |
#1097 |
Banned User
My Ride: Malfouf
#1098 | ||
#1099 | |
Now theres no way that our founding fathers could imagine the military advancements the government possesses right now but the heart of the law put us on equal footing with them at the time. HD was not at the heart of the law. |
#1100 |
My Ride: '03 330i ZHP Sedan
lol. 4 handguns. "AR-15 style" rifle was in the trunk, never brought into the school. Media lied, medical examiner lied. Good job liberals. Really.
http://video.today.msnbc.msn.com/tod...08495#50208495
| Rate This Thread | |
