E46 Xi Forum
Old 07-11-2013, 01:49 AM   #21
DavidDee
My Ride: 2004 325xi
Re: Ground control coilovers!!!!!!!
I PM'd you about the custom strut mounts.
Sent from my SCH-I545 using BimmerApp mobile app
"It has a radio and speakers but it's kinda hard to hear over horny bitches moanin in the back when I start it up.."
DavidDee is offline   Reply With Quote
Old 07-11-2013, 09:21 AM   #22
chaso
My Ride: 2001 330xi
Originally Posted by jony787 View Post
Update!!!! This is the new setup. I change the stock strut mounts for custom and the drop was almost 1 1/2 " more than last time so problem solved. For details please pm. If you are afraid to cut here and there this mod is not for you lol. Cheers!!!!!!
I really like the color of your car! Avus Blue?
Also, it's nice to see someone else who isn't afraid to go low. Your car sits about the same as mine and I'm on FK Highsports which ride like butter. Keep the pics coming!
chaso is offline   Reply With Quote
Old 07-12-2013, 07:06 AM   #23
jony787
My Ride: 318ti M52tu SWAP
Look for bmw 2002 or 320i for strut mounts, they dont fit on the hole i had to open the hole on the car also on the plate. Sorry for the delay. Check the pic!!! No interferance with the hood!!!!!!!! Almost 1 1/2 inches drop just that . Click image for larger version
jony787 is offline   Reply With Quote
Old 07-12-2013, 07:10 AM   #24
jony787
Thats lemans blue!!!!! I have ground control coil overs!!!! I 380 front and 480 rear and the ride is great. Also i adapted my shocks to use custom inserts on front. I reused to pay almost 300 bucks for each shrut when you can find a 40 bucks insert with the same valving. Cheers!!!
Old 07-12-2013, 11:18 AM   #25
bikesandcars
My Ride: 2002 325xi-sport pkg
This sounds like a nice bit of info. What $40 insert are you using?
bikesandcars is offline   Reply With Quote
Old 07-12-2013, 12:36 PM   #26
jony787
Rabbit 1984!!!!
Old 07-12-2013, 12:55 PM   #27
DavidDee
My Ride: 2004 325xi
Look for bmw 2002 or 320i for strut mounts, they dont fit on the hole i had to open the hole on the car also on the plate. Sorry for the delay. Check the pic!!! No interferance with the hood!!!!!!!! Almost 1 1/2 inches drop just that . Attachment 516016
Would it be possible to take material off the strut mount instead of the car?
Old 07-12-2013, 01:38 PM   #28
id3550
My Ride: 09 M3/4, 95 M3
Did the kit come with top hats? Also how to the perches stay in place, do they use the tension the the tightened perch makes? 380/480 spring rates seem stiff to me.
id3550 is offline   Reply With Quote
Old 09-18-2013, 11:46 AM   #29
choegatz
My Ride: 2002 325xi
such a bad idea to use RWD components with your XI.
especially when you're having to cut springs and mix parts and whatnot.
it's not too difficult to buy an XI variant coilover kit and be equally as low lol.
choegatz is offline   Reply With Quote
Old 09-18-2013, 12:40 PM   #30
SilvaBimma
My Ride: 330Xi
Where in NC are you? Love to see the setup.
SilvaBimma is offline   Reply With Quote
Old 09-18-2013, 06:57 PM   #31
rawbspear
My Ride: 04' E46 XIT 5 speed
these guys seem to have a lot of XI options in stock.
http://www.esetuning.com/category-s/6253.htm
rawbspear is offline   Reply With Quote
Old 09-21-2013, 03:28 AM   #32
Twin_Turbo_S54
My Ride: M3
I have GC Coil overs made specifically for AWD E46. Front struts are shorter compared to non AWD E46. Rear struts are very similar, although my rears were E46 struts...
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
