E46 Xi Forum
Old 12-16-2012, 11:20 AM   #1
Rockhopper
My Ride: E46 330 ci m sport
Engine light
Hi, I'm driving a e46 330ci. My engine light came on and it started to idle a little rough. I checked the breather pipes and found them clogged up with gunk so I changed the ccv and flushed all the pipes out with a air gun and inspected them for splits etc and replaced 1 of them.
Since doing this the car idles bang on but it's performance and fuel economy is very poor. The engine emmision light is still on?
Is the car in some sort of limp mode? Does it need reset which will hopefully improve performance and fuel ?
Thanks for your time and I appreciate any advice and help :-)
Rockhopper is offline   Reply With Quote
Old 12-16-2012, 03:35 PM   #2
adrian8507
My Ride: E46 325xi 2002
Replace your oxigen sensors bro thats whats going on right they are not reading how much oxigen is coming in or out .so is letting bypass all the gas and its not rendering fuel .hope it helped.
Sent from my SPH-D710BST using Bimmer App
adrian8507 is offline   Reply With Quote
Old 12-16-2012, 05:26 PM   #3
Rockhopper
Are the sensors the same? Isn't there two of them. It's only at low revs there's no power
Thanks again
Old 12-16-2012, 05:28 PM   #4
Rockhopper
Should say it does smell really rich now that I think about it
Old 12-16-2012, 07:29 PM   #5
adrian8507
Yeah there are two of them reolace them both for bettet emissions
Old 12-17-2012, 07:28 AM   #6
bmwbob89
My Ride: M-5 325 X3 528 740
Get the codes read out before you spend any money guessing what parts are needed.
bmwbob89 is offline   Reply With Quote
Old 12-17-2012, 08:55 AM   #7
SamDoe1
My Ride: 4cyl of fury
^ This.
Ignore posts 2-5 before you get the codes read, that will tell you what's truely wrong. Most auto parts stores will do this for free.
Old 12-17-2012, 09:40 AM   #8
Rockhopper
Bought a code reader today. Should be delivered for Wednesday . Thanks for the above advice. Will put the codes up on here for you all to look over and give me the best way to go with it. If it doesn't rain it pours though as I had a blow out on the rear today. Bridgestone tyre aswell with 6mm tread. Inner side wall has a 2" gash in it
Old 12-20-2012, 10:03 AM   #9
Rockhopper
Intake camshaft sensor?
Thanks guys
Old 12-20-2012, 03:47 PM   #10
SamDoe1
Thanks guys
Bingo, good luck!
Old 12-21-2012, 08:31 AM   #11
Rockhopper
All done and running a dream thanks
Old 12-22-2012, 12:52 AM   #12
Iggy27
My Ride: 2003 330xi
Or the idle control valve could be playing a little role in problems.
Iggy27 is offline   Reply With Quote
Old 12-27-2012, 04:15 PM   #13
hockey_fan
My Ride: 2000 323i
I haven't had any rough idle or stating problems (knock on wood!!) but I am getting the same code..camshaft position sensor. Are there two different sensors? I have seen the sensor shown with a long wire attached to it...and another one with just a plastic looking head. Is this the same sensor or are there actually two to replace. This is a 2000 323i 2.5L
hockey_fan is offline   Reply With Quote
Old 12-27-2012, 04:19 PM   #14
Rockhopper
Hi. For me it was the intake camshaft sensor. The one below the breather pipe for the ccv. Yes it has a long wire. Remove the cylindrical vanos thing to gain access. Night and day after that matey :-)
