Old 12-16-2012, 11:37 AM   #1
Dionne11
My Ride: 2004 325i
Help... Can't get the vanos off I'm stuck
I've gone as far as I can. I did the step by step instructions from beisen(s/p). I'm not sure how to get this thing off now.
Dionne11 is offline   Reply With Quote
Old 12-16-2012, 01:07 PM   #2
j_block
My Ride: 2003 325i
Did you take off all the bolts in the diy? Or did you break any?
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 12-16-2012, 01:19 PM   #3
BMWCaptain
My Ride: 03 325iT Sport Wagon
You did not remove the stud there in the right. You need to take the support bracket off first, then remove the stud.
I think you did not follow the procedure. You did not remove the caps to remove the hex studs connecting to cans.
Reread and follow beisans procedure.
BMWCaptain is offline   Reply With Quote
Old 12-16-2012, 01:37 PM   #4
Quicknick143
My Ride: 99 328i
Hey I'm new to this bmw forum I need lots of help with 99 328i sdn
Sent from my DROID X2 using Bimmer App
Quicknick143 is offline   Reply With Quote
Old 12-16-2012, 02:14 PM   #5
Dionne11
My Ride: 2004 325i
Mine is a double the procedure is for a single so I was trying to wing some of it. So both hex screws need to be loosened and I should be good right?
Old 12-16-2012, 02:36 PM   #6
Dionne11
My Ride: 2004 325i
The stud on the right was loose I would have taken it off had the vanos actually moved.
Old 12-16-2012, 05:13 PM   #7
TxZHP04
My Ride: ESS TS2+ ZHP
No need to wing it, Beisan provides a procedure for the double vanos M54:
http://www.beisansystems.com/procedu..._procedure.htm
Old 12-16-2012, 06:05 PM   #8
Dionne11
My Ride: 2004 325i
Thanks! This should solve it.
Old 12-16-2012, 08:05 PM   #9
BMWCaptain
Yes, Beisan lists procedures for all types of vanos.
You don't just loosen them, you have to remove them.
Oh, and by the way they are threaded as a left hand thread. It will loosen when turned to the right.
Follow their procedure and it will come off.
Old 12-16-2012, 08:45 PM   #10
Dionne11
My Ride: 2004 325i
I put everything back on, but ill try it again this weekend. Weird thing though after i put everything back on i check my codes and im getting an C3101 and C3400 after about 2 hrs of searching the code i cant find the reason and my engine makes a weird whining nose when i put my key in the on position before start up. Any of you ever heard of this?
Old 12-24-2012, 08:59 AM   #11
Dionne11
My Ride: 2004 325i
Fixed it this weekend. It's running way better! Thanks for the help.
Old 12-24-2012, 09:06 AM   #12
Mflara20
My Ride: 2002 330xi
I you want a easy DIY be sure to turn the bolts inside the vanos unit "left hand thread" but I'll be sure to buy new ones because they break easily
Mflara20 is online now   Reply With Quote
Old 12-24-2012, 09:07 AM   #13
BMWCaptain
Anytime.
