Old 12-16-2012, 02:55 PM   #1
haley's330
My Ride: 330
angel eye wiring question
So right now I have my angel eyes wired to the accessory cable in the fuse box under the hood, so they will come on as DRLs but I also wanted the fade in/fade out. So I ran a wire through the firewall and tapped the footwell light like most people do. My problem is that if I use only the footwell source they dont come on as DRLs and if i use both it complete a circuit and causes the interior dome lights to be on all the time.
how should i go about connecting it so i have both features? DRL and fade out
haley's330 is offline   Reply With Quote
Old 12-16-2012, 04:46 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
No idea what you are talking about.
Follow the steps on fastm.com and that's it. The trigger wire to the correct ECU wire will make the angel eyes turn on when the key is in position 2 and when the car is on. The other trigger wire coming from the relay has to go through the firewall and goes to the positive wire on the footwell light. That will make the angel eyes fade on/off when you unlock/lock the car or they will stay on when the interior lights are on. The ECU trigger wire overrules the footwell wire.
If you have DRL lights enabled find a shop or local fanatic that can code them off.
Old 12-16-2012, 08:22 PM   #3
haley's330
My Ride: 330
yeah thats what i did and the ecu trigger wire causes the inside lights to stay on
Old 03-20-2013, 11:15 PM   #4
fastsoup
My Ride: 05 M3 Vert/11 X3 M
Mr Solid,
I just ordered some LED Halos which comes with the relays so I can connect to the interior lights. My question is, I have disabled my DRL bulbs, and I want the HALO's to only be on when my headlights are off (so they are my DRL) and turn off when my headlights are off.
Which wire will I need to tap in order for this to happen for me?
fastsoup is offline   Reply With Quote
