Old 12-17-2012, 09:22 AM   #1
stevenherr83
My Ride: 2001 bmw 330i
completely at a loss and need help/opinions please
OK so ill try to keep this short but ill list what I have found and what has been replaced.
*my car is a 2001 bmw 330i with roughly 140k miles, still waiting for the dealership to give me all the service records on it though.
1 .hesitation solved :-)
2. My gas mileage tanked from 26mpg average to like 19-21mpgs.
3. My traction control will randomly activate when I have no loss of traction
4. Rough cold weather starts solved :-)
Parts replaced so far;
1. Valve cover gasket
2. Cold weather ccv system as well as all hides for it, throttle body gasket and o-ring for oil dipstick tube(the kit came with a long piece of vacuum tube but I have no clue what its for as there video(bavauto) didn't say anything about it)
3. Disa valve was replaced back in Feb 2012, but just replaced the o-ring on that and would appear that was causing my bad cold weather starts and hesitation?
4. Fuel filter w/ pr
stevenherr83 is offline   Reply With Quote
Old 12-17-2012, 01:56 PM   #2
ZemogFC3S
My Ride: '02 330xi
Does it hesitate around 3800 rpm?
When was the last time the fuel filter was changed?
~ '02 330xi
~ '89 RX7 TII
ZemogFC3S is offline   Reply With Quote
Old 12-17-2012, 02:05 PM   #3
stevenherr83
Not sure when it was changed last but I just ordered one this morning from bavauto. And the hesitation is throughput the rpm range, its like a lack of power with spurts here and there but very subtle if that makes sense? And thanks fir helping really appreciate it
Old 12-17-2012, 02:11 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you read the first 2 links in my signature. Look closely at the DISA and SAP system.
Old 12-17-2012, 02:13 PM   #5
stevenherr83
That's actually where I found my vanos info and I did read up on the info for the disa but didn't see anything about sap?
Old 12-17-2012, 02:14 PM   #6
Oqey
My Ride: BMW e46 330i sport
I am suspecting your crankshaft position sensor.
Oqey is offline   Reply With Quote
Old 12-17-2012, 02:16 PM   #7
stevenherr83
My mistake, intake can sensor was replaced in Feb
Old 12-17-2012, 07:55 PM   #8
jfoj
Originally Posted by stevenherr83 View Post
That's actually where I found my vanos info and I did read up on the info for the disaster but didn't see anything about sap?
SAP info is in my first link in my signature.
Old 12-24-2012, 08:10 AM   #9
stevenherr83
OK so replaced my fuel filter and everything went fine, pulled fuse 54 for fuel pump, started it till it shut off, swapped out the filter, turned key all the way forward to prime everything and then started it, got some roughness, which would be expected LOL, went for a drive and UT misfired pretty bad, turned the car off and pulled the key, put the key back in and started it again and she ran fine. Took a little over an hour trip the next day and bam cel came on. Decided to take it to autozone quick just to have an idea what comes up and when I went out to start it it wasn't on anymore but went anyways..for three codes, 1st was for iac, the other two were lean bank one and lean bank two...never really had an issue with Odell but some time will be around 600-700 and other times would be around 900 but doesn't jump around..my car seems to be running good now though..pulls pretty smooth and she smoked and sti so that's gotta say something right..lol
Sent from my LG-P999 using Bimmer App
Old 12-24-2012, 08:30 AM   #10
Zchild
My Ride: 2000 BMW 3XXi ZSP
A few questions for ya... Since you're well over 100k have you changed your pre-cat O2 sensors?
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 12-24-2012, 08:39 AM   #11
stevenherr83
Nope and fyi that's only one LOL..j/p
Old 01-11-2013, 09:23 AM   #12
stevenherr83
Well I finally got all the service records for my car..and back on Jan 31st when they replaced the intake distribution box that apparently meant the disa valve LOL..well that would explain why it was nice and tight but still replaced the o-ring on it LOL....pretty sure the hesitation issue is solved but still trying to figure put what is up with my electrical issue.. the entire electrical system fluctuates from lights inside and out to the heater/AC fan, to my idle..not very much just a slight dim and a slight up/down in rpms like 100-200 difference up and back down..I took a video of it to show what I mean but not sure if you can put that on here so ill upload to YouTube and post link
Old 01-11-2013, 09:24 AM   #13
stevenherr83
Old 01-11-2013, 10:44 AM   #14
scarede46er
My Ride: 2001 BMW 325i ZSP
Dude, my eyes are bleeding after reading your later posts. Would you mind inserting a little punctuation and line breaks? Thanks!
Old 01-11-2013, 10:50 AM   #15
WDE46
My Ride: '13 128i, '04 330Ci
Voltage regulator may be bad. How old is your battery? Have you checked the voltage through the OBC? That would fix your electrical problems probably.
Old 01-11-2013, 10:52 AM   #16
stevenherr83
Yep..here you go
Old 01-11-2013, 11:18 AM   #17
RayPooley
My Ride: 320i SE Coupe
Yes to this ^^^^^. Particularly the traction control symptom which I had. Took a while for the fault code to appear but once it did I replaced mine and ok. Word of warning though, the crank ps that was on it was only 9 months old but was not OE. So buy OE.
Old 01-11-2013, 11:23 AM   #18
My Ride: Lexus
You will keep having problems and playing guessing games until you actually properly maintain the car. That means doing the stuff in the second link in my sig.
Also those HID kits (especially cheap ones) don't belong in your high beams
Old 01-11-2013, 11:26 AM   #19
stevenherr83
OK I will check into this..thanks
Old 01-11-2013, 11:27 AM   #20
stevenherr83
OK well that's your opinion but everything has been maintained and have the records to show it. There are no lights on showing anything oil changed every 3,000 religiously and all service is up to date but thanks for your help
