Sponsored by BAVSOUND
Old 12-17-2012, 03:16 PM   #1
tindo
My Ride: e46 325i 2003
Alarm keeps going off
Just got a 325i 2003 but alarm keeps goong off when i lock yhe car, checked doors, trunk, engine bonnet, sunroof, all closed tight. What could be the problem?
tindo is offline   Reply With Quote
Old 12-17-2012, 03:48 PM   #2
My Ride: Lexus
Originally Posted by limpiabota809 View Post
Maybe fuse?
Please tell me, just exactly how could a fuse cause an alarm to go off?
OP: try unplugging your hood sensor (by the drug bin). often times it's been known to be that on the E39 models.
Old 12-17-2012, 04:29 PM   #3
limpiabota809
My Ride: 330 XI
deleted post for incorrect information
limpiabota809 is offline   Reply With Quote
Old 12-17-2012, 04:50 PM   #4
GodsSon
My Ride: 325i
when I first got the viper alarm system it would go off all the time. Eventually found out that it was something to do with the trunk sensor. I removed the fuse for the trunk sensor and its never given a false alarm since. Think it was something to do with the trunk light, but that would mean the trunk light goes off and on randomly at all times?
In God we Trust...all others Pay Cash.
_________________________________________________________
2005 BMW 325i
GodsSon is offline   Reply With Quote
Old 12-17-2012, 04:56 PM   #5
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Outback
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
my 2003Ci OEM BMW alarm did that until i replaced the hood sensor (by the drug bin) it's less than $10 and is a 30 second no tools swap.
VALMONT is offline   Reply With Quote
Old 12-17-2012, 07:46 PM   #6
shovelit
My Ride: 03 325xi and 04 330x
Do yo have a scanner like PAsoft?
shovelit is offline   Reply With Quote
Old 12-18-2012, 02:07 AM   #7
tindo
thanks for all the advice, sorry dont have a scanner. I will try to replace the hood sensor. Where is the trunk sensor though? have tried to look for it but have not found it.
Old 12-18-2012, 12:12 PM   #8
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
The hood sensor is the most common source of the alarm going off for no apparent reason, but, the actual source is stored in the GM5's shadow code memory. If you want to be sure you need to get the fault codes read out. If you are content shooting in the dark then start with the hood sensor,
scottjoh is offline   Reply With Quote
Old 01-06-2013, 06:01 PM   #9
Woowar
My Ride: M3 convertible
I have a 2005 M3 convertible and have had a similar problem. I noticed the alarm went off after I had been in the glove compartment. Once closed with a bit of force the alarm stopped going off. Might be worth a try.
Woowar is offline   Reply With Quote
Old 01-06-2013, 06:12 PM   #10
scottjoh
Modded ///Member
Sure if you don't mind trying and trying and trying until you happen to hit upon the source of the problem that's fine. If you want to get right to the source of the problem you need to read the fault codes stored in the GM5. It will tell you exactly what set off the alarm and how many times it's happened.
Old 01-06-2013, 06:44 PM   #11
Woowar
How do you get the fault codes from the GM5, how much is the equipment or how much for a garage to get them off?
Old 01-07-2013, 12:56 AM   #12
tindo
Thanks guys, it turned out to be the hood sensor, after I disconnected it, the problem has disappeared, just need to replace the hood sensor now.
Old 01-07-2013, 04:02 PM   #13
Woowar
Looks like mine may be the same after all. Let me know how much a bonnet sensor is when you get one please? Ta
Old 01-14-2013, 01:33 AM   #14
tindo
R585 from BMW
