Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
Rating:
Display Modes |
#1 |
Coil over selcetion
Hey guys been reading threads since 8am and can't decide weather to go vmaxx or race land ultimos coils I have a bagged 2000 e46 daily driver sedan have rocker coils and are junk so want to buy new ones but don't want to spend crazy money .. I have had vmaxx in my 07 Mini Cooper s but never race lands so if any one on here has used both on there e46 would love sum info / and also opnions thanks guys
#2 |
Grand Superpatriot
My opinion is to go stock. Don't put any DMAXX or Rokkors on your car. Dangerous and horrible
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#3 |
In my opinion, you should save a bit more for something higher quality, and would pass on the Racelands.
Kevin @ VMR | Wheels
Tel: 714-442-7916 | Email: kevin.a@velocitymotoring.com ![]() Facebook! | Flickr! | Blog! |
#4 |
Roxxor and Riceland are the same thing iirc. If your car is bagged, why do you need coilovers?
#5 |
Fully Deeked Out
You should post in the suspension section.
I hear they love to talk about suspensions there.
#6 |
Weagle Weagle
Bilstein PSS or PSS9. Done.
#7 |
Love my adjustable Bilstein PSS. World of difference from the stock (non-sport) suspension.
Guns up. |
#8 |
Wears carbon fiber boxers
My Ride: 330Ci ZHP 6sp
lolracelands
E46Fanatic's resident mathemagician
#9 |
My Ride: slow and sorta low
rocker is a sister company to raceland so same quality. You already have had vmaxx so if you liked them and want to go cheap then get them I suppose. But you are posting in a BMW community and the common answer is going to be buying quality suspension components. I went with KW and never looked back. ST is basically KW without the same coating on them to prevent rust, so if your not driving during salt/snow you could save a few hundred by getting ST
#10 |
If you are looking to stay within that price range we have Street Edge Coilovers. There is a review thread floating around here in the Suspension section. If you don't mind saving a bit longer I would recommend KW coilovers. The V2s are well liked within the E46 community. I personally run KW Street Comforts on my E60.
http://thesuspensionsource.mybigcommerce.com/e46/
Kristina "Kris" Ash
General Manager The Suspension Source 1-888-230-1288 kristina@thesuspensionsource.com www.thesuspensionsource.com Like us on Facebook for 10% off ![]() Last edited by Kris@TSS; 12-20-2012 at 04:50 PM. |
#11 |
My Ride: E46 323ci / E92 335i
The answer is simple; you get what you pay for when it comes to vehicle suspension. As such a crucial component of your vehicle, suspension is definitely something you do not want to cheap out on. A coilover suspension basically gives you a matched lowering spring and shock absorber combination with the added benefit of adjustable ride height and spring rates through a moveable spring perch or perches. Coilovers are to your car's advantage by reducing unsprung mass, increasing suspension travel, and allowing the car to be corner balanced.
You may want to check out the ST V1 coilovers if your on a budget. Coming from the makers of KW suspension systems the only main difference between the ST Variant 1 and KW Variant 1 is the steel they use. While KW uses Stainless Steel for their shock housing, ST uses Galvanized Steel. However, this does not mean a drop in quality, durability, or appearance. Although coilovers that use galvanized steel are more prone to corrosion due to environmental influences (i.e. mixture of salt water); those in the lower states: California, Texas, Florida, Nevada, etc. don't have to worry about corrosion. Those in the mid to upper States that snow still don't have much to worry about as long as they do not drive in heavy snow conditions upon where salt is used on roads. To further ensure those with doubt about Galvanized Steel, ST has corrosion resistant zinc plating on all of their threaded strut housings for further protection. They're significantly cheaper than the KW lineup and are a popular choice!
![]() We Specialize In: BMW Parts | BMW Tuning | BMW Tail Lights | BMW Wheels | BMW Lighting | BMW Intake Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006 Hours: Monday - Friday 8:00am-7:00pm / Saturday 8:00am - 5:00pm (PST) Last edited by ModBargains.com; 12-21-2012 at 08:08 PM. |
#12 |
You should definitely save a little more and get something of quality.
