Sponsored by The Tire Rack
Old 12-19-2012, 11:42 AM   #1
Stuttgart330
My Ride: 05 330CIC ZHP
Holy Batman! Rears gone after 9k!!
Well. As usual I can never go to a tire place without getting bad news. In for an alignment on my 330cic and the guy tells me I need new rears cause I have cords showing on the inside!!! You got to be kidding me!!??
These are almost new Kumhos from Tire Rack. I have just barely over 9k on these things. Never gone thru tires this fast.
Do I just have to deal with it?
2005 330CiC ZHP Hellrot - (mine)
2006 F350 Diesel CC - (Toy Hauler)
2009 528i Spacegrau Metallic - (wifes)
Stuttgart330 is offline   Reply With Quote
Old 12-19-2012, 12:14 PM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
At a minimum you need an alignment, highly likely you may also need to replace your RTABs.
Old 12-19-2012, 02:03 PM   #3
steifan
My Ride: 325i '06, 323 Ci '00
My 323 managed to wear the rears as seen on 2nd row here in less than 6000 miles:
About -6mm wear in 6000 miles.
The rears were ike the fronts before that summer - and I did no burnouts
BMW 323Ci '00, Eibach/Bilstein Pro-kit/B12
BMW 325i '06, M-Sport
steifan is offline   Reply With Quote
Old 12-19-2012, 03:14 PM   #4
JohnBlaze
My Ride: Black Sunshine
JohnBlaze is offline   Reply With Quote
Old 12-19-2012, 04:02 PM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Do you guys not buy tires with warranties? Pretty sure my tires have a 15k mile warranty
Old 12-19-2012, 05:59 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Sounds like your toe is off... Take it to a dedicated suspension shop so that they can inspect everything and perform an alignment.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 12-20-2012, 12:43 PM   #7
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Tread wear warranties typically do not cover wear due to a bad alignment or worn suspension components. Most summer performance tires do not have wear warranties on them anyway...Michelin is one of the few exceptions.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 12-20-2012, 05:52 PM   #8
djantlive
My Ride: E46 M3
I got the same thing. About 6k miles on my rears and inner side is worn to the cord.
Got an alignment, the Toe in and negative camber were off. Once dialed in to proper alignment, you can see the wheel is with a lot less negative camber. New Michelin Super Pilot Sports were installed before alignment. I hope they hold up well since they were $$.
Others have suggested RTAB as cause for this. My repair technician didn't see any issue with the suspension bushings. I am hoping it's not RTAB but if the uneven wear happens again, I will have to take the car to a BMW specialist.
djantlive is offline   Reply With Quote
Old 12-20-2012, 06:46 PM   #9
VMRWheels
VMRWheels's Avatar
My point exactly! Once the toe, camber, or both are out of spec you can pretty much kiss your tires goodbye.
Old 12-21-2012, 01:02 AM   #10
Stuttgart330
I have to replace my front bushings, left front was shot. Once I get that done, back in for alignment. But I suspect my rear is close to correct. Both rears have exact same wear on inside and shop says its simply due to the 1.5 to 2 degrees of camber that I'm running. I didn't think toe was adjustable on rear?
Old 12-21-2012, 01:27 PM   #11
VMRWheels
VMRWheels's Avatar
That little camber should not wear your tires in 9,000 miles.
Old 12-21-2012, 06:32 PM   #12
TxZHP04
Not if the toe is set correctly and the RTABs are in good shape.
Old 12-21-2012, 06:35 PM   #13
TxZHP04
Rear toe absolutely is adjustable. Whether it's from too much toe or worn bushings (allowing toe to change), the rear tires are experiencing excessive wear due to a toe problem.
Old 12-21-2012, 06:44 PM   #14
VMRWheels
VMRWheels's Avatar
Yup. Toe + Camber = Destroyed tires. If everything is straight but the camber is off, you should see tires last for a while.
Old 12-21-2012, 06:51 PM   #15
STORMER
My Ride: AA SC 98 M3
Yes I went through my last set of rears in less than 10,000 kms all because of toe in...
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
