General Off-Topic
Old 12-20-2012, 01:00 AM   #1
mdsonicTT
My Ride: 3rd gear
replaced broken laptop lcd with new one, new lcd is dim?
Replaced the broken LCD on my laptop with a new one, things are visible but EXTREMELY dim. I swapped my old one back in (which still worked after being dropped) but its dim also after having swapped the replacement in.
Any thoughts on what could be going on?
mdsonicTT is offline   Reply With Quote
Old 12-20-2012, 01:01 AM   #2
Wes
Wes's Avatar
Did you remember to delete system 32?
Wes is offline   Reply With Quote
Old 12-20-2012, 01:02 AM   #3
mdsonicTT
My Ride: 3rd gear
I don't think its a software problem. I did make sure windows booted a few times though
Old 12-20-2012, 01:09 AM   #4
mistrzmiasta
My Ride: GLK350,ML63, Duc1098
nah it's a software problem...delete macintosh and install miscrosoft and linux. without ms dos the screens are dim. go to "cd windows" in ms dos and delete system 32. hope this helps. good luck op. please stay safe OP.
mistrzmiasta is offline   Reply With Quote
Old 12-20-2012, 12:40 PM   #5
Top_Bunk
My Ride: Ram-Air Nylon
I think mistrz was drunk last night.
At the top & bottom of the screen there should be either LEDs, or a very thin (and delicate) CCFL tube. Check all the connections to these, something may have been pulled loose or damaged when you swapped the screen.
Top_Bunk is offline   Reply With Quote
Old 12-20-2012, 12:52 PM   #6
Tauce says
My Ride: is imola
No backlight?
Tauce says is offline   Reply With Quote
Old 12-20-2012, 06:27 PM   #7
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
most likely bad inverter
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
Old 12-20-2012, 06:32 PM   #8
mistrzmiasta
i was....op pm'd me that he really needed help and to edit my post so the thread would be taken seriously. i apologized but forgot to edit the post.
Old 12-20-2012, 06:58 PM   #9
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Build a GUI from bash, you'll be good to go. Make sure it's threaded parallel though, you'll have problems if it isn't.
Old 12-20-2012, 07:13 PM   #10
v8 5
My Ride: 6 speed BMW
threads about it
Gutted with a Getrag
We have 4 websites within the family.
v8 5 is offline   Reply With Quote
Old 12-21-2012, 02:48 AM   #11
Andy2108
My Ride: SpecE46 & E46 M3
It's probably a problem with the cable that connects the motherboard to the screen itself. I went though this with my Thinkpad. Check to make sure the connections are all connected and secure. If that doesn't work, order a new cable. Mine wasn't very expensive ($30???)
