Australia
Old 12-20-2012, 06:00 AM   #1
gabileung
My Ride: 330ci
EOI::[SYD]: High End Audio Gear Genesis/Audison/Morel/Optima/Accuvolt
Hi Guys
expression of interest of my beloved audio gear built for my e46 spare tyre well install.
ID:	482820 Click image for larger version
ID:	482821 Click image for larger version
ID:	482823 Click image for larger version
ID:	482824 Click image for larger version
component consist of following:
AMP Stack:
2 x Genesis Series 3 Dual Mono (top 2)
1 x Genesis Series 3 4 Channel (bottom)
1 x Audison BitOne
1 x Accuvolt FR-1500 Voltage Regulator
1 x Optima Yellow Top
1 x dual batt charging management unit
1 x Brax 100a fuse block
1 x 3 ways individual distribution fused block
1 x 4 ways distribution grounding block
4 x custom silver RCA signal connect
+ various 2ga/4ga/8ga power cables for your spare tyre well install
Speaker:
1 x Morel Elate6 3 ways Limited Edition (89th/500 worldwide)
1 x a pillar pod for tweet and mid
AMP stack pretty muuch plug and play.
have all power cables you need for spare tyre well install with multiple grounding and to car batt in perfect length.
all gear in mint condition apart from a bit dusty on top...
additional pic available on request
not consider to break down AMP stack component at this stage.
feel free ask any questions.
PM if interest.
gabileung is offline   Reply With Quote
Old 01-07-2013, 01:05 PM   #2
sadpanda03
My Ride: 2003 330i
What size speakers do the pillars hold?
And will you consider selling them by themselves?
sadpanda03 is offline   Reply With Quote
Old 02-04-2013, 12:30 AM   #3
gabileung
My Ride: 330ci
that built for holding the following:
Mid:
Unit Diameter 88mm (3.50")
Mounting Depth 21mm (0.83")
Mounting Cutout 75.5mm (2.97")
tweets:
Unit Diameter 45mm (1.8")
Mounting Depth 20mm (0.8")
Mounting Cutout 50mm (2")
