Old 12-20-2012, 05:57 PM   #1
Dirty-330
My Ride: 330ci,325xi,m3c
AutoZone fuel filter only 1 inlet/outlet per end
Seasons Greeting All!
Took a trip to Buffalo today from Toronto, went to AutoZone to get chevron techron 2for1(and outlet shopping). Just my luck the big bottles that are 2for1 were sold out. Anyway picked up a fuel filter while I was there, when I got home and checked it out it only has 1 inlet/outlet per end.
The guy searched proper car, 01 bmw 330ci and sold me this filter, I see on the DIY walk thru there are 2 inlet/outlets per end.
Is this filter useless as far as using it in my car? 01 330ci
I garbaged the box an receipt at store.
Thanks in advance
Dirty-330 is offline   Reply With Quote
Old 12-20-2012, 06:00 PM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
Yes it is useless. The one that you need has a built in fuel regulator, thus, two pipes. Autozone will take it back and will give you store credit with an ID.
Old 12-20-2012, 06:21 PM   #3
BimmersGarage
My Ride: E46 330i
it's the wrong fuel filter. Your's need the regulator built-in.
Go exchange it.
BimmersGarage is offline   Reply With Quote
Old 12-20-2012, 06:23 PM   #4
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
i'm guessing yours is for a 328 or (m52tu) car.
mine has only one inlet and one outlet as described. it is genuine bmw.
the m54 calls for a different one i believe.
Old 12-20-2012, 06:46 PM   #5
Dirty-330
Thanks guys.
Ill call autozone and try to get the receipt recovered, might be a while before im in the States again tho.
Old 01-17-2013, 11:16 AM   #6
DonaldE
My Ride: 2002 330i
Where is the DIY write up for changing fuel filter?
DonaldE is offline   Reply With Quote
Old 01-17-2013, 11:20 AM   #7
My Ride: Lexus
it's under the driver's seat area. pretty self-explanatory once you get down there.
pull fuse#54 to assist in depressurizing the fuel line (start car a couple times without the fuel pump fuse in place) and make sure you have one foot of Genuine BMW fuel line and new clamps ready to go.
Old 01-17-2013, 11:27 AM   #8
spdracr137
My Ride: 323i
There's a diy section on this forum. Look at the diy collections thread that is stickied at the top. Pretty much all maintenance diy's can be found there. Took me 5 secs to find it.
http://bimmerinfo.com/diy/fuel-filter/
spdracr137 is offline   Reply With Quote
Old 01-17-2013, 12:01 PM   #9
hummer
My Ride: 2001 330CI
Have some vac hose at the ready also as mine crumbled when removed!
