Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Old 12-20-2012, 06:32 PM   #1
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
4dr E46 B Pillar Removal w/Photo's
I wasn't able to find anything showing how to remove the B-pillar(s) with pictures online so decided to put one together.
This was done on a 2004 330i 4dr different models may vary.
1. Remove front and rear door sills.
2. Lift up (hard) and out on the lower b-pillar trim panel
Notice the rivets that you pulled the lower b-pillar over. (I found it difficult to get the lower b-pillar back over these when I was putting it back together so I replaced them and put them in the lower b-pillar first and it snapped in no problem.)
3. Remove the expanding rivets at the bottom of the upper b-pillar.
4. Pull down on upper b-pillar and it's free.
SEAT BELT
A. Start at the rear of the seat to take the control module cover off
B. Take the cover off. There are clips that are connected underneath the cover; make sure not to break them.
C. There is a lug nut that keeps your seat belt in place, remove it.
D. Fin
Hope this helps anyone who needed a visual aid on how to remove their b-pillars.
omni01_k is offline   Reply With Quote
Old 12-21-2012, 02:11 AM   #2
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
BMW /// 323i
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 12-21-2012, 11:07 PM   #3
Levim9
My Ride: S54 325i & LSB M3
Exactly what I needed. I'm swapping out my B pillars right now. Thanks for the DIY
Levim9 is offline   Reply With Quote
Old 12-21-2012, 11:48 PM   #4
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
Originally Posted by sellsellsell2000 View Post
Glad to help.
Old 12-23-2012, 06:56 PM   #5
josephi
My Ride: '02 330i
I want to replace mine as they have seat belt wear marks. This will make the job much easier for me. Thanks for posting it!
josephi is offline   Reply With Quote
Old 04-09-2013, 03:28 AM   #6
Hunter msport
My Ride: E46 320 M Sport
Originally Posted by omni01_k View Post
It looks so sad to be out
Hunter msport is offline   Reply With Quote
Old 04-09-2013, 11:17 AM   #7
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
Hahaha
Old 06-18-2013, 05:48 PM   #8
BHTowler
My Ride: 2003 325i
Same process for the passenger side?
B. Towler (Carrollton, GA)
Moxxxi - '03 325i
BHTowler is offline   Reply With Quote
Old 06-19-2013, 12:15 AM   #9
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
Yes it is the same process.
Old 06-19-2013, 06:41 AM   #10
Sansho
My Ride: 2001 325i
Nicely done.
Sansho is offline   Reply With Quote
Old 11-01-2013, 11:47 AM   #11
TOURING
TOURING's Avatar
My Ride: M3 Vert/M5/M3 coupe
Thanks for this!!!! shouldnt be too much different for coupes i hope
TOURING is offline   Reply With Quote
Old 11-01-2013, 12:37 PM   #12
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
Slightly but not by much. Here is a link for the coupe though.
http://forum.e46fanatics.com/showthread.php?t=948819
Old 08-04-2014, 09:45 PM   #13
bimmerboy25
bimmerboy25's Avatar
My Ride: Bagged 2002 325ci
If my b pillar is broke, what would I need to replace it, the seat belt and lower portion won't stay in place
bimmerboy25 is offline   Reply With Quote
Old 08-04-2014, 10:48 PM   #14
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
You have a picture of the broken portion? If it's where the plugs go into to keep in place, try using a washer if there is still some plastic left. If not you could get another b-pillar and just go about it that way.
http://www.ecstuning.com/BMW-E46-330...Trim/B_Pillar/
Old 08-04-2014, 10:55 PM   #15
bimmerboy25
I think it's the plus are missing but not 100 percent sure, but I'll send pictures when home.
Old 08-05-2014, 11:05 AM   #16
bimmerboy25
The seat belt won't stay in place, i gave managed to get it to stay but if the doors are slammed or the seat belt is pulled hard, the top portion holding the seat belt uasuly comes out
ID:	567985   Click image for larger version
ID:	567986   Click image for larger version
Old 08-05-2014, 11:11 AM   #17
bimmerboy25
Here are some pictures of it just sitting in place, the main question I'm asking is, will I need a new pillar or just plugs?
ID:	567988   Click image for larger version
ID:	567989   Click image for larger version
Old 08-05-2014, 03:25 PM   #18
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
I would suggest a new pillar. Looking at the one in the picture you posted it looks like the portion where the plugs are used to keep it in place are broken off. Someone may know a way to jerry rig it but I don't.
I attached the last picture from above so you can see what I am referring to with the two holes at the bottom of the pillar. Those are used to keep the pillar in place. In the picture you posted those two parts are broken and the bottom half (of the hole) are missing.
Hope this helps.
Old 08-05-2014, 05:05 PM   #19
bimmerboy25
Hope this helps.
Well what about the bottom portion, the areas that secure the bottom portion seam to just be missing the plugs/screws, i ordered some off eBay but not sure if their what I need for it. And earlier some guy mentioned using washers and then placing the plug through that. I could try that
Old 08-05-2014, 10:20 PM   #20
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
The washers might work and if you're trying to keep spending low it may be a good route to go. Worth a try, washers are pretty cheap.
The bottom portion of the b-pillar need the plugs to keep it in place.
