Old 12-20-2012, 06:38 PM   #1
grdg
My Ride: 330 XI
trunk release with key only
The trunk will only release with the key. Remote, lid switch and under dash button do not work. Valet proof is not the problem. What test can I do on
the micro switch to isolate the problem? No fuses listed on the sheet in the
glove fuse box. grdg
grdg is offline   Reply With Quote
Old 12-21-2012, 01:28 PM   #2
z69ss
My Ride: 2000 323i
Pull the wire harness next to the right trunk hinge down. Just pull the rubber boot off the body and check for broken wires. Very common issue.
z69ss is offline   Reply With Quote
Old 12-21-2012, 03:16 PM   #3
djantlive
My Ride: E46 M3
^^ this.
djantlive is offline   Reply With Quote
Old 12-21-2012, 03:29 PM   #4
grdg
My Ride: 330 XI
Not much wiggle room with the wire bundle. The rubber boot is ripped so this may be the problem, thanks.
Old 01-01-2013, 01:34 AM   #5
saxual328ci
My Ride: 2004 325ci
Did you by chance lock the trunk? You know if the keyhole position is to the right, then it's lock. You can only access it with the key.
saxual328ci is offline   Reply With Quote
