Old 12-20-2012, 06:52 PM   #1
swedeking
My Ride: 2003 325
Xenon Ballast Resistor Keeps Failing on Drivers Side
First, thanks in advance. This forum is great. New to working on BMWs and this forum and the posts have been super helpful in helping me work through issues on my girls 03 325i - which makes me me look cool to her.
Now to my problem with the Xenon headlights
1. Headlight quit working on drivers side
2. Ordered replacement bulbs (cause I wasn't smart enough to search here first)
3. Swapped bulbs - still no light
4. Swapped ballast resistor - problem switched sides - ok, sweet it is the ballast resistor.
5. Working ballast resistor now swapped to drivers side fails. - Crap no headlights now.
6. Swap again just to confirm - yep both ballast resistors now failed - coincidence or problem? Hmm
7. Go to local BMW salvage place (Autobahn Parts in San Diego is great) - and get 2 ballast resistors and install them there. Both headlights working. Sweet.
8. 3 days later girlfriend tells me that drivers side headlight is starting to flicker
One additional piece of information. It was raining when it started to flicker this last time.
Does anyone know of anything that could cause the ballast on the drivers side to fail twice and now maybe three times? I understand water may be the problem but before I go spend money on another ballast resistor I want to eliminate all other possibilities - that is I dont want to swap another in and seal it up good and it still fail.
Also, if water - is this coming more likely coming from below and getting in through the seal where the ballast resistor mounts or is coming from the front and running down to the ballast resistor?
Sorry for the long post but I wanted to be as thorough as possible with what I have done.
Thanks!
Steve
swedeking is offline   Reply With Quote
Old 01-24-2013, 06:39 PM   #2
swedeking
My Ride: 2003 325
OK, so I am hoping someone can help with this additional information.
I decided to take part the good and bad ballast resistors.
Here are picture of both a good one and a bad one. Notice the red circles on the bad one where it looks like blown circuit pieces.
Any ideas on what might cause this? Want to prevent it happening again. 2 ballasts have already been blown and they aint cheap.
There is also a picture of where the ballast attaches. Notice the wire insulation has come off and stuck to the housing. Doesnt seem to me like this could cause a real problem since it only touches plastic but also doesnt seem good.
Thanks in advance!
Name:	bad Controller.jpg
ID:	487620   Click image for larger version
Name:	Good Controller.jpg
ID:	487621   Click image for larger version
Old 12-12-2013, 03:23 PM   #3
Spinoza
My Ride: 330D
I suffer from exactly the same problem
I also have burnt 2 ballast on the driver side. I opened it up and it's burned in the same way. Exactly the same sircuits.. I do not know why but I got the feeling this ballast was warmer than the other side
Spinoza is offline   Reply With Quote
