///M3 Forum
The BMW E46 ///M3 is the M version E46 and puts out an amazing 333 HP and 262 lb-ft of torque at stock specs! There are an amazing amount of modifications for both the coupe and convertible models so read up and get started modifying your cars today! |
Rating:
Display Modes |
#1 |
Launching
How do use guys Launch a SMG M3 with out launch control. Kind scared to use launch control lol.
#2 |
My Ride: E46 M3 Vert 2012 X5
Obviously your not balls to the walls.
![]() Last edited by danwilz; 12-21-2012 at 03:31 PM. |
#3 |
#4 |
Lmao I'm just asking how u guys do it
I put my foot on brake rev to 2 let go of brake and hold on lol Tracking off, S6 , and sometimes sport on doesn't do much. But launch control scares the **** out of me not trying to brake my pump agin.. Last edited by Ballstowalls; 12-21-2012 at 06:10 PM. |
#5 | |
"! First rule of Italian driving, that which is in your mirror is not important !"
#6 |
Im sure there's a difference launch control puts the whole tranny under tremendous stress and pressure. I don't think I'm putting as much stress with the way I launch please correct me if I'm wrong.
#7 |
When you use launch control the car has the clutch disengaged - the way you are doing it the clutch is engaged, car trying to move forward and you are "holding" it back with the brakes. If anything, the way you are 'launching' the car is harder on it compared to using the 'real' launch control as you are putting a load on the transmission..
#8 | |
![]() |Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's| |Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters| |
#9 | |
And I have a convertible Aren't the subframes reinforced?? So will I be fine Last edited by Ballstowalls; 12-21-2012 at 07:22 PM. |
#10 |
What your currently doing is putting a stress on the whole drive train. Are any of them enough to hurt the car? My opinion is no. With that being said its a real inefficient way to launch. LC is exactly the same as dropping the clutch in a normal manual car. There is nothing magical going on when you do this. Since the clutch is controlled by electronics that drive hydraulics, LC allows you to have the car in 1st gear and drop the clutch at your demand.Euro spec software is upwards of 4k rpm when it lets go, now that is a effing launch!!
#11 | |
#12 | |
#13 |
And you have a vert too so don't worry too much about the subframe.
#14 | |
#15 |
My Ride: 2 pedals - 2 paddles
LC and Burnout mode are initiated the same way with a small difference. For LC mode, you press the accelerator pedal slowly to the floor. For Burnout mode, you stab the pedal to the floor.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof Get your "M" on . . . Reading is FundaM3ntal ![]() CAR: 2003 TIAG Coupe / Blk Interior / SMG / HK Premium MODS: EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB BMWCCA NCC |
#16 |
From one SMG guy to another, what am I missing?? For LC you must hold the shifter forward in S6. I have not noticed a quick or slow pedal mash to make a difference while doing this. I have done both holding the stick keeps the clutch engaged, so no difference IMO. Burn out is just S6 and a full pedal mash from a stop. Im just trying to clear it up for those less informed.
#17 | |
#18 |
For either mode,
DSC off S6 Shifter forward ** for Launch Control ** just slowly roll the pedal to the floor. OR ** for BurnOut Mode ** mash the pedal to the floor Launch Control will attempt to not so harshly engage the clutch to reduce wheelspin. (Tires and suspension greatly affects one's sucess) Burnout Mode will fully lock the clutch enabling burnouts NOTE: There are a number of other tricks that you can employ depending on which program your vehicle has (NA or EU) I have the EU3/CSL program. Also, the LC usage is stored in the DME
Joy is future proof Get your "M" on . . . Reading is FundaM3ntal ![]() CAR: 2003 TIAG Coupe / Blk Interior / SMG / HK Premium MODS: EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB BMWCCA NCC Last edited by turbo_f22_pilot; 12-21-2012 at 11:14 PM. |
#19 |
Thanks for all the info guys
#20 |
I would not launch my SMG ever. To much to pay for a massive SMG failure, I do track the balls off it though....
04 Jet Black SMG - NAV
Cinnamon Sonic Tuning Spacers 15mm \\// More to come...:shifty: Valentine V1 BMC filter Full real carbon trim to include seat backs and paddles Scorza Euro Header+Cat !*!!* All EURO parts : m3e46freak@yahoo.com !!**!*! ![]() |
