Go Back   E46Fanatics > E46 BMW > Sponsor Press Releases & New Product Announcements > Site Sponsor Specials and Sales
Find out about the latest specials and sales from our site sponsors here!
Old 12-21-2012, 10:06 PM   #1
obd2toolbox
Past Site Sponsor
My Ride: BMW 7
BMW GT1 DIS V57 SSS V41 Compatible with IBM T30
BMW GT1
Description:
DIS Version:V57
SSS version:V41
BMW GT1 language available:
DIS system: English,Chinese,German and Russian
SSS system:English,Chinese,Japanese,Korea,Thai,Spanish,Italian,D utch,Greece,Swedish,Indonesian,Turkish,Portuguese,French and Russian.
Features:
BMW group tester one (GT1) is offered to the aftermarket in the same specification that is currently supplied to BMW franchised dealers. It is special-purpose tool of BMW Series.
Gt1 is supplied with a Pentium based laptop PC on a Windows platform connected to a high specification communications and measurement interface.
GT1 can complete coverage of ALL BMW systems, one thing that can only be done using the GT1, this function is called Electronic Control Unit (ECU) programming and configuration. Many of the original electronic systems on modern vehicles can now be re programmed using software; historically any changes to rectify software problems would involve a new ECU which would be purchased from the parts department and that is the only way that the independent market today is able to overcome these problems. The BMW GT1 system allows you re programme all BMW car ECU's to fix software or to install a blank ECU to a repaired vehicle. GT1 is the only system that allows you to do this and is absolutely essential if working on Freelander , the GT1 is also the only system that provides all diagnostics and programming for the very latest BMW launched this year.
BMW GT1 software kit comprises of five system ,TIS system .DIS data system ; diagnosis system .measuring system and management system . you can to test and check data information same time in GT1.
Test function :
Read faulty code ,clear faulty code ,data stream .activate state,programming ,component test ,maintenance data information ,components location ,wiring diagram etc.,TIS AND DIS ARE SUPPLY all of system diagram of all of BMW car, Components location, maintainence method and coding information etc. Can do completely of BMW car system.
Package includes:
1. GT1-SCAN Pro mainbody
2. Network cable
3. GT1 for vehicles with 20pin diagnostic connector
4. GT1 for vehicles with OBII diagnostic connector
www.obd2supplier.com Professional OBD2 Online Supplier
BMW Diagnostic tools and BMW Key Programmer
BMW Scanner 2.0.1 BMW Scanner 1.4.0
obd2toolbox is offline   Reply With Quote
car diagnostic tool, obd2
