Australia
Old 09-03-2012, 04:52 AM   #1
Dazza9421
My Ride: 318i E46
E36 gearbox in E46?
Is it possible to fit an E36 gearbox into and E46? I have been trying to find an answer but can't seem to get any info.
Mines the early E46 so its got the M43 which is similar to E36 M43? and gearbox model numbers are same but part number is different.
I did speak to someone and he says "Even though they are both dual pan the plugs at the rear of the transmissions are not compatible" - I have sent him an email about modifying the plug but he hasn't got back to me yet.
Can someone give me some information about this? or if someone on here has done it. Can the plug be modified from an E36?
Dazza9421 is offline   Reply With Quote
Old 09-04-2012, 01:39 AM   #2
tedelex06
My Ride: E46 323i S/C
Yes, I have the E36 M3 5sp (3.0, 328i) gearbox in my E46.
tedelex06 is offline   Reply With Quote
Old 09-04-2012, 01:46 AM   #3
Breyton-BMW
Breyton-BMW's Avatar
My Ride: Ti
Send a message via AIM to Breyton-BMW Send a message via Yahoo to Breyton-BMW
Yes for the M43 they are the same shitty Getrag unit for both the E36 and E46. Ask me how I know.
Here's a pic of mine when it was pulled down because it lost 5th gear. It happened around 80,000 kilometers.
If I cross reference my part number, this comes out.
http://www.realoem.com/bmw/partxref.do?part=23007505600
http://www.realoem.com/bmw/showparts...16&hg=23&fg=05
Breyton-BMW is offline   Reply With Quote
Old 09-04-2012, 03:23 AM   #4
NBMW
My Ride: A BMW
MSportBMW is running the E36 M3 6spd box. You can also run the S54 tranny with some modifications.
NBMW is offline   Reply With Quote
Old 09-04-2012, 06:39 AM   #5
Dazza9421
My Ride: 318i E46
Mines an automatic with the GM Dual Sump gearbox. All the replies i got is for regarding manual gearbox's aren't they?
Apparently whats different is the ?harness? that plugs to the gearbox?
I just want to make sure that an auto box from an E36 will fit my car before purchasing one and not being able to fit it
Old 12-16-2012, 03:17 AM   #6
samers
My Ride: E46 318i 1999
Yes it will fit. Just need to replace the selector switch.
But I am not sure, if the gear ratio will be different or not, that may impact performance.
What did you do ?
samers is offline   Reply With Quote
Old 12-16-2012, 03:28 AM   #7
Sherweeeny
My Ride: BMW Civic
For future reference, gearbox = manual
Transmission = automatic
Sherweeeny is offline   Reply With Quote
Old 12-16-2012, 03:53 AM   #8
Jall
My Ride: 328Ci
.....wut?
Jall is offline   Reply With Quote
Old 12-16-2012, 11:52 PM   #9
Shonky
My Ride: 2004 E46 M3
Rubbish. Both terms are equally valid interchangeably for automatics and manuals
automatic transmission = automatic gearbox
manual transmission = manual gearbox
Shonky is offline   Reply With Quote
Old 12-17-2012, 12:55 AM   #10
Goondaddy
My Ride: 2002 325ci
Tranny = Sherv
Goondaddy is offline   Reply With Quote
Old 12-17-2012, 06:38 AM   #11
trive2
My Ride: 1989 BMW 535i
Originally Posted by Goondaddy View Post
Tranny = Sherv
trive2 is offline   Reply With Quote
Old 12-17-2012, 04:41 PM   #12
Sherweeeny
My Ride: BMW Civic
Yeah that's fine, but if I'm going to post a specific question and not specify what I'm talking about, I can at least subconsciously hint. If the op said I want to change my transmission, then my bet would be so many manual comments won't have been thrown out.
Old 12-17-2012, 04:41 PM   #13
Sherweeeny
My Ride: BMW Civic
Tranny = Sherv
You'd know!
Old 12-18-2012, 01:28 AM   #14
samers
Friends,
Thread subject "E36 gearbox in E46", not how to specify gearbox type !
Old 12-22-2012, 10:39 PM   #15
Dazza9421
My Ride: 318i E46
What did you do ?
I ended up selling the car and got something different as most people were saying that the gearbox (or according to this term i didn't know about, TRANSMISSION for automatics) will fit each other but the electronics are not the same and will cause problems so i decided not to try it and a friend of mine who had an idea on how to fix it bought it off me.
conversion, e36, e46, gearbox, transmission
