Old 12-22-2012, 03:06 PM   #1
Airborne82id
My Ride: 330CI
What's the adjacent light for?!
After almost 10 yrs of ownership and several e46's, tons of diys, then this ...LOL
Seriously, I turned my high beams, went around to take a look; The same running light got brighter, the second adjacent light stayed off. Car equipped with xenon.
My previous e46, when I turn the high beams, the adjacent lights turns on. But it had halogen.
Airborne82id is offline   Reply With Quote
Old 12-22-2012, 03:08 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
It's called Bi-xenon. Search and you will find out what it does.
Old 12-22-2012, 03:36 PM   #3
Airborne82id
My Ride: 330CI
Not gonna lie ... it wasn't easy searching. Had to go to google ..
Still ... I have no light coming outta the adjacent light?
I can't incorporate the following data "moving a shield up or down in front of the bulb (depending on the reflector design) to allow light to escape from the lens in a different pattern" When I have nothing to work with?
Old 12-22-2012, 03:47 PM   #4
Airborne82id
My Ride: 330CI
I understand the same projector works as regular and high beam .. hence it's called bi xenon. Which what I have stated in my initial question without naming it.
And my question still stands; what's the second light for?
Old 12-22-2012, 03:49 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
When you pull the stalk back the inner parts light up.
When you push forward the bi-xenon activates.
Old 12-22-2012, 04:50 PM   #6
shovelit
My Ride: 03 325xi and 04 330x
I could be mistaken, but I think the inner lights are also the daytime running lights. If you have this feature disabled, obviously, you wouldn't see them.
shovelit is offline   Reply With Quote
Old 12-26-2012, 02:07 AM   #7
328iKid
My Ride: 2013 Ford Mustang GT
Like Jake stated, the inners light up when stalk is pulled back, this is the "flash-to-pass" feature. The inner halogens lighting up are easier to distinguish from a bi-xenon high beam.
328iKid is offline   Reply With Quote
