Sponsored by BimmerWorld
Old 12-22-2012, 05:35 PM   #1
addbhp
My Ride: 2001 330ci vert
Ill handling 330ci after install new winter rims and tires
Looking for advice, and insight. I just installed new winter tires and rims, 225/45/17 square set up on 17x8 rims and now the car is almost undriveable on the highway. Car is darting and need to make constant adjustments to the steering wheel, that never had to be done with my stock staggered set up. Feels like driving in a wind storm but it's calm out.
And now anything over 130km/hr the traction control like goes crazy and starts grabbing the drive wheels, even on dry pavement. Traction control is even working when turning at normal speeds.
Directional tires mounted correctly, no wires disconnected as I switched rims myself.
Any insight appreciated. Already not impressed by Tire shop, but will go back if needed. Car has gone from handling well to crap.
Mark
2001 330Cic
addbhp is offline   Reply With Quote
Old 12-22-2012, 05:39 PM   #2
[USMC]Skywalker
My Ride: 2004 330i
what tires (brand) and make sure they balanced the tires, unbalanced tires will handle very badly at high speed including vibrations.
[USMC]Skywalker is offline   Reply With Quote
Old 12-22-2012, 05:43 PM   #3
E46330iguy
My Ride: Supercharged 330i
Sounds like you need an aligmnet
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/Borla/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 12-22-2012, 06:07 PM   #4
addbhp
There is no vibration, so ruled out balancing. Tires are Hankook. But will definitely do an alignment, fingers crossed that solves it. Weird I wouldn't feel it with the summer set up.
Mark
2001 330Cic
Old 12-22-2012, 10:42 PM   #5
rwall
My Ride: 2004 325ci
Check the sidewalls to make sure all are the same aspect ratio (all 45's). If one is different, it'll have a different circumference and screw with your speed sensors. If this doesn't help, temporarily swap your summer set back on and see if the symptoms persist, indicating a new, coincidental suspension or alignment problem. Good luck.
rwall is offline   Reply With Quote
Old 12-22-2012, 11:51 PM   #6
JQuick5156
My Ride: 2004 330 Coupe
I had a similar situation as this....need an alignment however I also need fcab and probably ball joints....I'd check that stuff out. For some reason it's not noticeable with my summer set up but my winter tires made it very obvious....doing my control arms after Christmas sometime.
JQuick5156 is offline   Reply With Quote
Old 12-26-2012, 08:38 AM   #7
obd2toolbox
Past Site Sponsor
My Ride: BMW 7
PP2000 Peugeot
obd2toolbox is offline   Reply With Quote
Old 12-26-2012, 08:45 AM   #8
stevenluczynski
My Ride: Is Steel Blue
Originally Posted by obd2toolbox View Post
whats with the sponsor spamming
stevenluczynski is offline   Reply With Quote
Old 12-26-2012, 09:05 AM   #9
willsbma
My Ride: 99 323i
You sure the tread is facing the right way
Sent from my DROIDX using Bimmer App
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 12-26-2012, 10:27 AM   #10
Toad21
My Ride: 00' 328CI
Put it on a lift, put in in neutral, and just spin the tires and look. They will have a wobble, and your tires are either not mounted correctly, there is something wrong with the tires (happened to me), or your suspension components are bad. And a possible combination of any of those.
Not really worth asking on here, more of a common sense solution.
Toad21 is offline   Reply With Quote
Old 01-02-2013, 10:07 AM   #11
SoloII///M
My Ride: Many
Have you used the wheels before? What's the offset as compared to stock? If you have lower offset wheels (i.e. pushed out towards the fenders more) you have increased the scrub radius in your suspension which will cause tramlining. Also, certain tires are notorious for horrible tramlining. I had a set of Bridgestone RE760s that were about the worst I'd ever experienced in that regard.
I'd get the alignment checked out. Check also for loose wheel bearings or worn tie-rods or ball joints. Any of these things can cause dynamic toe and camber changes as you drive down the road which will cause the symptoms you're encountering.
John
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
