Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
#1 |
Where's a 12v wire under the hood?
Simple question = simple answer
Looking for a 12v wire I can tap to power an LED light for the exterior. I've never done anything electrical with this car so everything I've searched on these forums and many, many others is over my head. Any help MUCH appreciated |
#2 |
*bump
#3 |
cigarette lighter
#4 |
Your jump start terminal, ie. the little black box with the "+" sign near your right strut tower.
Edit: you may want to find someone more knowledgeable to help you through this project. If the location for getting power is not obvious, then some of of the electrical dangers might not be obvious either. Last edited by mkodama; 12-23-2012 at 03:39 AM. |
#5 |
My Ride: 04 M56,LC 100,RX300
When do you want the light to come on?
Sent from my ADR6425LVW using Bimmer App
#6 |
i'd want the light to come on whenever i start the vehicle. i figured if i attached it to the battery terminals it would always be on, which is not ideal.
the cigarette lighter sounds like it might work, but which wire is it. i've tried looking up electrical diagrams but can't find one. all i could gather from online was something about a purple and white wire and maybe a red an yellow one without the dots, but those are for different models. |
#7 |
If you only want it to come on when you start the car or put the key in switch 2 then maybe the accessory wire might be your option
#8 |
i finally found a pic of the accessory wire, it's the red wire with white stripe and yellow dots. i'll tap that one and ground over by the jump terminal, unless there's a wire somewhere i can tap into for that?
#9 |
Got it working:
Now that I've taped into that accessory wire does that mean that if I try to install AE's I can't use that one? Or can you have multiple taps going into one line? |
#10 |
I think you should be able too. Just make sure it gets the proper ground.
- Christian
BMW M3 E46 | Carbon Black Metallic | Gray Nappa | ZCP | SMG | 40% Tint | LED Interior/Exterior Join Us at the San Diego North County Monthly BMW Meet ![]() |
#11 |
I did a similar wire set up to mine but in the taillights. Where the outer LEDs on the tail light and the rear foglights were connected to the brake lights. As long as you ground correctly it should be good
- Christian
#12 |
I ran the ground for this one to the 19mm bolt over by the battery jump. I intend to run the angel eyes off the same accessories wire and ground in the same spot.
#13 | |
If you draw too much load from that accessory wire, short it, or send a power surge back through it, you risk expensive electrical damage that will literally immobilize your car. With your current setup by the way I understood your description, if that lighting wire accidentally gets damaged and shorts, you'll blow an engine compartment fuse and your engine won't run if that fuse blows. Last edited by mkodama; 12-24-2012 at 01:38 AM. |
#14 |
Is that based on how it's grounded or because it's drawing its power from the accessory wire?
#15 |
