Sponsored by The Tire Rack
Old 12-23-2012, 03:42 PM   #1
redgiem
My Ride: e46 touring and 745i
225x45x18 325xi wagon - tire fitment
I'm new here however I've been driving BMW 745i and Audi Allroad. I just recently sold the audi and just bought a 2003 325xi wagon. I purchased sets of rims and tires (tire size 225x45x18 and rim size is 18x8.5 offset 40).
The rims and tires is now in transit via UPS, for my peace of mind any of you guys have the same set up? Wanted to make sure it will NOT rub in the front and back. Please adviseÖ
thanks!
redgiem is offline   Reply With Quote
Old 12-23-2012, 03:45 PM   #2
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
I have the CSL reps that are 18x8.5 with 225 40 18ís front and back that donít come close to rubbing on Eibach Pro springs. Donít remember the offset of the CSL reps, but you should be ok.
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 12-23-2012, 05:13 PM   #3
redgiem
Hi,
I hoping NOT to replace or upgrade my suspension, can I leave it the way it is?? with 225x45x18 tires and 18x8.5 rims - it will stick out correct??
thanks!
Old 12-24-2012, 09:31 AM   #4
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
I would be concerned with possible rubbing up front with 225/45R18.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 12-24-2012, 09:41 AM   #5
davidwarren
Halfway to 2L
My Ride: 2010 335i
Originally Posted by redgiem View Post
Hi,
thanks!
I only included that to show that mine donít rub with dropped suspension, so stock suspension would be less of a concern. However, Gary would know for sure- what tires did you order?
BTW- I just looked at the variance between 40 and 45 series in the tires I run, and the 45 are an inch larger in diameter. That could be enough to make a difference.
Old 12-24-2012, 01:17 PM   #6
redgiem
Thank you guys! Tire size 225x45x18 and rim size is 18x8.5 offset 40 - I'm hoping it will fit rightÖ :-((
Old 12-26-2012, 02:30 PM   #7
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
That's taller than I'd recommend for your car. Should be 225/40/18.
You might have some rubbing.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 12-26-2012, 02:31 PM   #8
Juliopinto03
My Ride: 2000 328i
Same size for a 328i sedan ?
Juliopinto03 is offline   Reply With Quote
Old 12-26-2012, 02:34 PM   #9
VMRWheels
VMRWheels's Avatar
Yup, same sizing on the sedan as well.
Old 12-26-2012, 03:24 PM   #10
redgiem
Yeah... the difference between 225x45 and 225x40 is less than 1 inch or 0.8 inch taller - so I'm hoping it won't be a problem, but IF I have some rubbing do know if will be at front or back or both?? Can I use spacer to fix that??
thanks!
Old 12-26-2012, 03:35 PM   #11
Juliopinto03
My Ride: 2000 328i
Explains why I got rid of my 19s way too much rubbing with rear passengers lol
