Old 12-25-2012, 08:43 PM   #1
GATORSHOES2
My Ride: 2002 BMW 325i
Orion V4 night controller wiring.
Yes I have search, and searched, and even searched a little more the past few days.
Was getting the V2s but umnitza called and said they were out of stock and bumped me up to the V4s.
So this means I'm getting the night controller, where do I wire it?
I know it's wired to the low beams, and I know which wire on the orion harness itself, but what wire on the car? Pics would be great.
GATORSHOES2 is offline   Reply With Quote
Old 12-26-2012, 07:27 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
No angel eyes are ever wired to the low beam.
This is the DIY for the angel eyes themselves
http://www.fastm.com/m3/angeleyes_orionv2.html
Can you post a pic of the night controller wiring? I've done a ton of installs but not the V4's
Old 12-26-2012, 11:41 AM   #3
GATORSHOES2
It's suppose to be where when the low beams come on, the rings dim to 70%
According to this, it's tapped into the low beam wire. Seems simple? Just odd. IT'S E and D.
Old 12-26-2012, 04:14 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
That makes no sense sorry to say.
Old 12-26-2012, 04:30 PM   #5
morningisbad
My Ride: E46 M3 Vert
This is correct, you are supposed to wire to the low beam positive so that the angel eyes dim when the headlights are on. SolidJake, this is NOT the case with the V2s as you pointed out.
This step is totally optional though. I didn't do it on my V4s. I like them bright!
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein
morningisbad is offline   Reply With Quote
Old 12-26-2012, 04:31 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
Ah alright, thanks for the info.
Old 12-26-2012, 08:38 PM   #7
GATORSHOES2
Everything is wired up and looks great! I did skip the dimming option for now as the end on the white wire wont plug into the provided wire taps...
So I have to go get my own wire taps for that. But I might just tape off the ends and avoid it all together.
Old 12-26-2012, 09:09 PM   #8
UmnitzaSupport
My Ride: 1995 m3
how does it look, post some photos
happy?
Join Our Facebook! - Check Out Photos, Talk to Customers, Ask Us Questions!
Call Tim K. 877 486 6489
Email Konstantin D. umnitzaship@gmail.com
Available: 9am-5pm M-F
UmnitzaSupport is offline   Reply With Quote
Old 12-26-2012, 09:26 PM   #9
GATORSHOES2
happy?
Got dark on me and the iphone won't take a very good picture from a distance.
Here's a close up for now.
Lights are a pure white, with a very slight blue tint. But I have 6000k xenons so it matches perfect. Some people have complained about the V4s being too blue? I only see that problem in a refection of the lights.
So far i'm very happy with the V4s.
Looking to get my LED tails from you guys over at umnitza.
Old 12-27-2012, 06:45 AM   #10
coolioj
My Ride: '02 330i
So I just installed my V2 with Night Controller, but I haven't connected my white wire, as I'm unsure if the yellow wire in this picture is the one I want to connect it to. Can someone confirm this is the right one? Yellow wire on the big connector, correct?
coolioj is offline   Reply With Quote
Old 12-27-2012, 01:58 PM   #11
GATORSHOES2
My question was "where is the wire for the low beam that I'm supposed to tap into?"
After getting everything wired and saw the length of the night controller wire "white" I knew it was going to be right where you show in the picture, and the other wire is brown/dark right? If so then yes the positive is the yellow you showed.
Old 12-27-2012, 06:06 PM   #12
coolioj
My Ride: '02 330i
Ok, thanks. Umnitza also confirmed it was the yellow one. Will do that tonight.
